Rear shock strut replacement?
Saw this on my rear shock strut yesterday. It looks to be leaking. Any ideas on replacement cost? Any OEM or what brand/part numbers to replace? This is a 2015 250 F Sport. RWD
Yep, she’s leaking.
I used KYB rear shocks on my 2014 IS350 non-F last year when I saw the same leaking on mine. Got them from RockAuto, better price than OEM. Car feels the same.
bmwlexus09 (04-10-21)
This video should be helpful. He's installing coilovers, so ignore the stuff about the springs and just worry about the bolt/nut locations. You shouldn't have to worry about taking anything apart in the back suspension. The shocks should compress with a bit of muscle. :
As for parts... It's a good time to decide if you want to upgrade. But if not, OEM works great, but the cheaper options will get you on the road.
bmwlexus09 (04-11-21)
Pretty simple, and the only tip is something I saw in a video, and that is removing the luggage tie downs in the trunk. There’s a plastic flap in the tie down that needs to be lifted to access a bolt holding the tie down to the floor. Sure you can find it in a video.
