Maintenance items as you reach 100K
Hi,
Long-time lurker, first-time registered user. I tried to search for this info, but was getting bits and pieces of information — feel free to point me to a sticky that I probably missed.
I have a 2014 RWD IS250 that I bought CPO with less than 20K on the clock. After the 4 included services ran out, I did all the maintenance. I was religious about oil changes, and making sure all the scheduled maintenance was up to date. I changed the plugs at 60K, and swapped the front struts and rear shocks at 90K, along with the upgrade to the RC-F LCA bushings in the front.
Now that I'm at 96K, wondering what preventative maintenance is advised? I'm thinking of the following:
Thanks!
- coolant flush
- upper and lower rad hoses
- water pump
- transmission fluid
- diff fluid
- belts?
Thanks!
IMO - Follow your Service Manual, not the Lexus Dealership.
LEXUS MAINTENANCE SCHEDULE
1. Every 5K Miles or 1 Year - Engine Oil and Filter Change
2. Every 30K Miles or 3 Years - Engine Air Filter, Cabin Filter Change
3. Every 40K Miles or 4 Years - Spark Plugs Change
4. Every 50K Miles or 5 Years - Brake Fluid Change
5. Every 100K Miles or 10 Years - Engine Coolant, Intercooler Coolant Change
lexuscanuk (05-06-21)
I know it says that the Tranny is sealed and can't be flushed but others have done it and they know that the fluid looks old. At 100k miles, i would look at an independent shop to do a tranny flush as tranny fluid doesn't last the lifetime of the car.
Make absolutely sure to use the toyota tranny fluid which is expensive but designed for that car.
