Displaying current gear on 3IS cluster
Can someone with a 3IS F sport cluster kindly tell me is it able to show the current actual gear that the car is in? I know if you switch the shifter to the sport mode and use the paddle-shifters then it shows the gear you select but is there a way to see the actual gear that the car is in? Specially if not in S mode? Thank you
I’ll take a video after if u need it let me know
ahmed24 (05-07-21)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x971/20210507_153910_93c3ac274ed2297c8826db5abcc59ffa85b00d1b.jpg)
Go to the information "i" menu, and scroll to the 2nd last option: "gear position". It'll show the gears once you're in drive.
ahmed24 (05-07-21)
you can push the button on the left side of wheel that slides over gauge, 1 of the displays in there is current gear. You can also push the up/down select button on the right side of the wheel and that will cycle through small displays on the gauge...one of them is gear.
