IS250 Radio Replacement
Hey guys
I have a 2014 F sport. My radio number is p10433.
Could I replace it with a different one from 2015 or 2016 that comes from an F sport too? I see them for a few hundred bucks but the number seems to be different?
Does anyone know a cheap audio repair shop in socal?
There are 300+ other threads on the topic and I think it can be a different year before but has to match that number on the unit (which may be year specific).
It's very easy to change yourself, 20 mins. I can send you a video when your ready or if your in the SD area show you how to do it.
Received 1,738 Likes
Ideal scenario is to get a radio with the same faceplate ID that you mentioned.
It doesn't matter what year vehicle it's from, it just needs to have the same faceplate ID number.
It is possible to use another faceplate ID, but likely the radio is from a different country, which means you'll likely need a new micro SD map card probably, from the dealer, which is a cost that needs to be factored in.
For US you basically have 3 radios from 2014-2016:
The connectors between Navi and Non Navi units are different, so they cannot be interchanged.
The Premium Audio unit also has additional wiring that accounts for the Mark Levinson system.
- Standard Audio, non Navi
- Standard Audio, with Navi
- Premium Audio, with Navi
What I mean is that for the 2016 model radio that has the same standard audio with navi, its P11010 which is different than the one I have in 2014. The connectors all look the same except for the addition of a brown connector.
Hey guys I bought the 2015 radio p11010 and it fit my 2014 IS250 radio P10443. Everything seems to be working correctly. Now I have to figure out what to do with my broken radio and where to sell it.
Hi, I'm from Ukraine, that's why I'm writing with the help of a translator.) I'm sorry) I also faced this problem, I stopped working P10443, I read that you put the P11010 and everything worked well, I did it, but I don't turn on, i can hear that the fan works, and heat, but the monitor does not turn on, maybe you need flashing?
I would check all the connectors on the rear of the radio.
