LED amber turn signals
LED amber turn signal replacement
My ‘14 250 AWD has regular tungsten (1156?) amber bulbs at all 4 corners. Can I replace them with LED bulbs?
I would want high quality/bright units if possible.
TIA!
TIA!
Are you sure it's 1156 and not 7440/7444 bulbs? You can fit LEDs regardless, you'll need resistors for them to prevent hyper flashing as well.
I recommend Alla Lighting 7443 Ambers
For resistors, if you don't want to tap into wiring I recommend these Load Resistors
Gasturbine (08-31-21)
I should have been more clear, I want them AS BRIGHT, as OEM. My primary reason, is I don’t like the way tungsten bulbs that “glow” on, then off…I like/want the bulbs that are instant on/off, like LEDs are.
