What's the best option/modification you added on your IS
Old 09-21-21 | 12:59 PM
Soldat79's Avatar
Soldat79
Whoismiled (other guys too ) thinks for share that all with us. For me the F-Sport gauge cluster swap is very very nice. But not for a hybride I have only one gear 🤣. But why not one day ?! 🙂
And the Front lower grill fisheye camera + beatsonic it s very nice. Before you didn t have rear camera too or you had? I m intressting, I would be sure when I park my car the front bumper don t hit somethings hiden.
Old 09-21-21 | 01:08 PM
whoismiked's Avatar
whoismiked
Yes, my car has a OEM backup camera. I just added a camera to the front lower grill. Then the beatsonic interface allows me to press a button and it will turn my front camera on, press it again and it turns my rear camera on (anytime I want, car doesn't have to be in reverse), then press it a 3rd time and it will go back to normal screen. It's also programmed to go back to whatever previous screen I was on after 10 seconds of pressing the button and that timer can be changed to whatever timer, or no timer, you want.
The back camera works just as normal when putting the car in reverse, so I just added a front camera and a button to control camera views (beatsonic).
Hope this makes sense
Soldat79 (09-21-21)
Old 09-21-21 | 01:49 PM
Soldat79's Avatar
Soldat79
It s very clear, at least for me . It s my next mods before half spring down.
whoismiked (09-21-21)
Old 09-21-21 | 01:53 PM
Soldat79's Avatar
Soldat79
Originally Posted by dteskmo
Best mod for sure has been the Figs LCA bushings! Saved my tires from premature wear, and don't squeak like the RR Racing ones
Have you got a link, I had rcf bushing that make nothing or not perceptible for me.
Old 09-21-21 | 02:01 PM
Soldat79's Avatar
Soldat79
I saw the video to install the front fisheyes cam, I afraid to install it I need to make a weld
Old 09-22-21 | 06:20 AM
whoismiked's Avatar
whoismiked
It is not a must to use a soldering Iron. You can simply use crimp / but connectors, like these:
Or you could also have a car audio shop install if for you
Old 09-22-21 | 06:51 AM
Soldat79's Avatar
Soldat79
Oh yes a crimp or wire clip connectors , good idea.
Old 09-22-21 | 09:42 AM
CASeoul's Avatar
CASeoul
https://shopfigs.com/v3/SUSPENSION-C...bushings/L1025
If you have access to a press you can buy the bushings only and press them into the oem brackets
https://shopfigs.com/v3/SUSPENSION-C...LCA-SP3491K-90
Soldat79 (09-22-21)
Old 09-22-21 | 10:35 AM
dteskmo's Avatar
dteskmo
This is what I did... saves a lot of money!
Soldat79 (09-22-21)
Old 09-23-21 | 03:49 AM
wongnee's Avatar
wongnee
Figs LCA bushings? What is that?
Old 09-23-21 | 02:07 PM
arentz07's Avatar
arentz07
Not sure if joking... but just in case you aren't, "LCA" means "lower control arm".
Read about the inner tire wear issues here - https://www.clublexus.com/forums/is-...tire-wear.html
Old 09-23-21 | 02:08 PM
Soldat79's Avatar
Soldat79
Figs LCA bushings, have you noticed that the car pulling less to the right or the left when you drive fast ? Do you need to add grease ?
Old 09-23-21 | 05:33 PM
CASeoul's Avatar
CASeoul
Didn't have any pull prior to installation, car was driving fine.
It lost that "dead" or "floaty" sensation at speed and during turning. It comes with grease for the install.
Soldat79 (09-23-21)
Old 09-23-21 | 11:45 PM
Soldat79's Avatar
Soldat79
Floaty, that's what I meant to say 😁. Nice.
CASeoul (09-24-21)
Old 09-25-21 | 02:10 AM
Soldat79's Avatar
Soldat79
I bought rcf bushing brakets three month ago (I m not happy about it) and after read you I would like replace in my RCF bracket by the Fig bushing do you think that will be ok to go in.
