LCA Bushings
LCA Bushings
Hello! I've been reading a lot on this Forum about switching out the IS LCA Bushings to GSF/RCF, I'm about to order a pair for myself. I'm quite new to this but is there anything else I should be ordering (Bolts, etc) or does the OEM one work?
Bushing Part # 48075-24010 / 48076-24010
Also is there a difference with these on AWD IS350s and RWD IS350s as I own an AWD variant!
Thank You
Thank You
Direct swap so you don't need to order anything else. AWD and RWD are the same part. GSF / RCF are RWD vehicles btw
The following 3 users liked this post by swaangin:
Received 1,738 Likes
^^ +1 Agreed
And original bolts are fine to reuse.
Watch out for the fluid when you remove the long 22mm bolt.
I just swapped mine about 2 months ago. When you go to torque down the bolts, make sure you are looking at the correct specs for AWD. I have a RWD and didn't scroll down far enough down the post and only tightened mine down to the AWD specs. It was about 40 ft lbs off, if I remember correctly. I drove it like that for about a week before I realized and had to go buy another torque wrench to do it correctly.
https://www.clublexus.com/forums/sus...-offset-2.html
Spartan8
08-22-20 05:43 PM
