F sport cluster and tyre pressure
Can anyone with the F Sport cluster kindly tell me, is it possible to see the tyre pressure itself on the f sport cluster or is it just the warning?
Thanks
Thanks
You can see it, you move the gauge cluster with the button on the steering wheel (on the right). It'll display more info, you have to go to the first tab and scroll through options (mpg, eco mode, etc) and there should be a display for tire pressure of each tire
Received 1,737 Likes
Depends on the country/region you are in.
In North America the cluster will display the tire pressure (regardless if it's an F Sport or not)...but in some eastern hemisphere regions it does not, and it is purposely done that way.
I can also see my tire pressure by using the arrow down button on the right portion of my steering wheel. It will cycle through fuel mileage, tire pressure etc...There is like 4 or 5 displays.
arentz07 (10-05-21)
drives cars
^ Correct. Sometimes it won't show up until I have driven a short distance (showing "-" for each tire), but I can get it to show up in either the larger info view or in the centered-tach, smaller view.
If you try cycling through all the options (using the up and down buttons on the steering wheel), and you still don't see it, perhaps it is not available in your area.
I guess the first thing to determine is what is stopping the cluster from showing you the pressure...it is the cluster or the Main Body ECU.
In North American IS' if you use aftermarket TPMS sensors sometimes the pressures don't show and you just get the dashes...but the TPMS light is not on.
So in that case, the cluster is capable of showing you the pressure, just something is telling it not to.
For the most part the cluster is just an information centre showing you data that is collected from various other computers in the vehicle.
What region are you in?
swaangin
10-11-21 11:33 PM
cerberusM5
06-01-21 11:33 AM
