Suspension input - rear camber arms
So pretty much everyone knows the tire wear issue with the IS, mostly the rears. My car not only has a pretty solid wear issue but also doesn’t stay in alignment very well as the roads around are fairly garbage. Anyway, I’ve read a lot about how to remedy the issue and have come to the conclusion that I will be placing:
- new bushings (RR Racing Ultimate Steering Response System R&T - I know they have to be lubed intermittently and a lot of people have gone with RCF bushings but have seen mixed reports of the RCF ones not quite being the answer for some)
- rear camber arms
additionally while I’m at it I’ll be putting in RSR downs and going with new wheels and tires
my question: do I want an adjustable rear camber kit like the SPC Performance Camber Rear Camber Arm-72450 (Here) Or SPC Performance Adjustable Rear Camber Arm (Here)?
I’m fairly new to all of this and am not seeing the difference/advantage of one over the other. Additionally I’m assuming any normal shop can install these and know how to align with them?
any input is greatly appreciated!
- rear camber arms
- rear camber arms
- rear camber arms
im just thinking the camber arms will help things stay in alignment and also allow me the correct adjustment in case my wheel/tire choice doesn’t keep camber in spec. I figure at about $350 if it can keep things aligned better that’s cheaper than pre-maturely killing tires.
Sponsor
The 72450 is for the 3IS. the other are for 2IS.
-Justin
RR Sales
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Your #1 Lexus Vendor
72450 is the one to get, very popular for us among with lowering springs or coils.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
If you're going to get lowering springs, you're going to increase the negative camber (and inner tire wear on the rear).. so you definitely want to get camber arms in the back if that's what you're concerned about.. personally, I haven't noticed much difference in wear after getting springs
