3IS LED High Beam Adjustment (for lowered cars)
Noticed recently that the LED high beams are pointed too low (low beams are perfect), below are the steps that I've tried. Anyone else have any idea on how to adjust LED high beams?
Steps I've tried:
Steps I've tried:
- Manual adjustment via flat head
- Re-initialization (https://www.clublexus.com/forums/is-...ur-dealer.html)
drives cars
whoismiked (01-04-22)
Thanks for sharing! The pics say that both high and low beams are attached.. hmm that might be the answer to my question, but doesn’t solve the issue that the high beam is pointed down too low
I'm pretty sure high and lows on twin beam headlights are generally on the same casting. Meaning you can't separate them. You can go left or right and up and down. If you believe one is abnormally lower than the other, then maybe the unit has prior damage. Other than that, not much you can do other than replace or manual repair.
