Lexus 19" GS F wheels on 2018 Lexus IS 300 AWD
5th Gear
Hello guys, again, I have a question on wheels for my 2018 IS300. I think the answer is yes, but haven't found a definitive answer or pictures elsewhere. The wheels I'm looking at have the following specs:
These are Lexus RC F-Sport wheels:
8x19 40ET
9x19 50ET
From my previous post, the following would fit:
9x19 50ET
10x19 41ET
So I am thinking they should fit even better? Thank you always for any advice!
8x19 40ET
9x19 50ET
9x19 50ET
10x19 41ET
Received 1,738 Likes
The RC F wheels would fit better based on the specs you provided.
I would point out, depending on what look you're going for, that they would not be flush with the fender at all.
If you're going for a flush look, consider adding a 20mm spacer to the front...you could also consider a 25mm spacer as well.
For the rear at least a 10mm spacer...you might even be able to squeeze a 15mm on also.
Final tire sizes would also dictate what the maximum spacer size could be, as well as if the vehicle is lowered or stock height.
5th Gear
Yes...the other specs you provided we high for the front and low for the rear. They could have been made to fit, but the RC F wheel specs will simply fit just fine as is.
5th Gear
Thank you for always being responsive on this forum and for the helping hand. The wheels I was considering are these:
https://parts.lexus.com/p/Lexus_2020...TR5630130.html
It has been hard to find pictures of a 2016+ IS300 with these wheels on. I want to make sure that the fronts clear the brake calipers with 40ET offset; thank you.
drives cars
palpullero
01-07-22 07:53 AM
