Purchasing a 3IS with 100k miles
7th Gear
Hey everyone, new to this side of the forums, regular on the LS400 threads. I've noticed that there are a few IS's of varying engines/options around me for sale used with anywhere from 75k to 100k miles. What is you input on getting one with this kind of mileage? Obviously I know this isn't a lot for a typical Lexus - but not familiar with the newer ones. I'm aware of the inner tire wear issue as I plan to resolve that if I decide to get one. What engine choice would you say is the best to go for? Any options to look out for or to avoid (F sport or no F sport)? Thanks in advance.
My recommendation would be to get the 3.5l V6 engine, there are no turbos in that and you get more power plus there is also the AWD option with those. My mechanic told me the V4 turbo engine had an undisclosed engine recall but I never looked into it as I don't care for turbos and went with the 3.5l V6 instead. With the IS the only real issue is if they were driven too hard like any car and you are correct about the inner tire wear but that is not a major issue and is an easy fix. Just make sure your trusted mechanic inspects it for anything shady if you are not dealing with a respected Lexus dealer.
The packages are different in Canada, we get them bundled where as in the US they are split up to an extent so I don't think the F Sport 2 [which I would recommend for Canadians] means anything in the US as it does in Canada (everything except the rear shade and turning headlights that are included in the luxury package that is below F Sport 2, do I miss not having the shade or turning lights no but that's me).
IS350 / IS300 best choice but I personally don't like a car at that mileage because it's probably went through significant wear & tear but your view on this may be different than mine
I think that even 100k miles is okay as long as the car is still in good condition, it has been maintained regularly, and it gets a pre purchase inspection. For example, cold start up and see if there is evidence of smoke in the exhaust, drive and shift through the gears automatically or manually, and so on. A good tech would be able to provide a better assessment of the car during the ppi.
The best engine choice at that mileage is going to be the one in the IS350, which is the 2GR-FSE from 2014 - 2017, then the 2GR-FKS from 2018+. Both are basically the same 3.5L V6 engine, the latter has extra VVT tech to get better fuel economy, updated injector design, integrated exhaust manifold, and other stuff. I would not look at the 2.0T or the 2.5L V6, the 3.5L V6 is where it's at, smooth, powerful, sounds good, bulletproof.
As for options, I would definitely go for F-Sport because you get the following things:
Depending on where you live, you may also want to look for a car with AWD, which is what mine is (IS350 AWD F-Sport). It's a great, old school AWD system that's full-time and 30% front / 70% rear torque distribution, which changes up to 50/50 as needed. This comes with the 6 speed auto, which is much better than people make it out to be. It's smooth in auto mode and almost always in the right gear. The only downside is that if you drive slowly or normally and try to use manual shift mode (by moving the shifter to the left and then tapping up/down on it, or using the paddles), the manual shift speeds are slow. You have to be driving faster, with more throttle input, and then the shifts become acceptably quick. If you look up TheTopher on youtube, he did a review on an RC350 AWD, you can see the manual shift speeds to get an idea of how fast they are.
- Sport S+ driving mode
- Adjustable dampers and steering wheel weighting
- F-Sport steering wheel, sportier front seats, aluminum pedals, shifter
- black headliner
- sportier grille
- 18" F-Sport wheels (one of the best OEM designs, IMO)
- F-Sport LCD gauge cluster with sliding ring inspired from the LFA
- Blind spot
- Mark Levinson sound
- Parking sensors
- Triple beam LED headlights (2018+, I think)
- Heated/Ventilated seats
- Heated Steering wheel
GeorgeSaad (05-28-22)
