2014 Is350 F Checking headlight system with low beam not working
Old 10-30-22 | 02:06 AM
jac16's Avatar
jac16
2nd gear
Default 2014 Is350 F Checking headlight system with low beam not working
Hey guys
My 2014 Is350 had the check headlight system sign on. Apparently, the low beam on the passenger is not working but everything works fine. Since I had the dual led light, I’m not able to replace the bulb. The thing is that the light was working perfectly the night before, it just went bad after driving for 30 minutes in a sunny weather the next day.
I want just wondering would it be possible is the headlight control unit? Cause I replaced the headlight like two years ago, and the bulb should last longer. There is no sign of condensation in the light either.
Old 10-31-22 | 09:14 AM
PrimeDave's Avatar
PrimeDave
If that bulb was replaced only 2 years ago it shouldn't go bad that quickly, no way. Sounds like your ballast is going bad, not the bulbs...
Old 10-31-22 | 09:47 AM
arentz07's Avatar
arentz07
If they are factory LEDs, there's no ballast to worry about. LEDs do not have ballast unless they are retrofitted to replace HIDs.
Old 10-31-22 | 04:28 PM
jac16's Avatar
jac16
2nd gear
Yea, I have the dual LED headlight so it wouldn’t have a ballast.
PONgs350
07-07-21 12:29 PM
BTC89LS400
10-08-20 07:43 AM
keltonks
11-04-18 05:41 AM
gearheader
CT 200h Model (2011-2017)
06-19-18 01:50 PM
wilsonwho
Lighting
09-19-17 02:07 AM
