Rear Camera Trim Removal
1st Gear
I have a 2017 Lexus IS 300 and my rear camera is broken. I am trying to replace it myself, however, I cannot get the trim surrounding the camera off. As far as I can tell I need to remove these grommets somehow. Anyone have advice for how to get these things off?
Thanks!
Part in question:
https://parts.lexus.com/p/Lexus_2017...0153100A1.html
Picture of grommets from inside the trunk:
Thanks!
Part in question:
You can use long needle nose pliers and press on the two tabs on each side (left and right) then pull from the outside or push from the inside. I believe that should allow you to remove the camera, the top and bottom of that plastic piece doesn't look like there are locking tabs so you should be fine.
lS3000 (11-21-22)
Really????
kj07xk (11-21-22)
jonas's RX
04-29-19 09:26 AM
Acer
01-24-13 09:37 AM
