How is the 8 speed rwd transmission?
Currently selling my 07' is250 and looking for an is350 3is, found out that the AWD has the 6-speed transmission that I am used to but the RWD has an 8 speed dual clutch transmission. Want to know how this performs, is there a big difference? Is it worse than the 6 speed? I would appreciate all the commentary and knowledge you guys have. Thankyou.
EDIT: Also heard that even in manual mode the car autoshifts right before redline, is this true? Is there a way to disable that?
I have driven both the 8 speed auto version in the RX350 F-Sport AWD (Same as the one in the IS350 F-Sport RWD) and I own an AWD IS350 F-Sport. Having extensively driven both, the 8 speed is much better than the 6 speed auto. The engine needs to be kept near its powerband as it is a bit of a peaky engine and the 8 speed does a better job at that. It is not a dual clutch, but still it feels very snappy for an auto even in the IS350 F-Sport RWD. No slushbox feel in manual mode. The 8 speed auto rev matching is also better than the 6 speed auto rev matching. It is still very different from the 8 speed AISIN in my RCF where the torque converter completely is locked out in manual mode and also software tuning is a lot more aggressive/faster and the gearing is different. Still the 8 speed in the RWD IS350 (or RX350 F-Sport AWD) is geared more optimally to work with the powerband, From my experience, the 6 speed auto is geared too long. In a 1/4 mile acceleration, interestingly their test numbers seem to be nearly identical of around 13.9 - 14.0 seconds, though.
Regarding the auto upshift, I found a solution to that in my 6 speed auto. If you disable traction control completely (hold the button down for 3 seconds), it will allow you to bounce off the rev limiter.
drives cars
I have driven both the 8 speed auto version in the RX350 F-Sport AWD (Same as the one in the IS350 F-Sport RWD) and I own an AWD IS350 F-Sport. Having extensively driven both, the 8 speed is much better than the 6 speed auto. The engine needs to be kept near its powerband as it is a bit of a peaky engine and the 8 speed does a better job at that. It is not a dual clutch, but still it feels very snappy for an auto even in the IS350 F-Sport RWD. No slushbox feel in manual mode. The 8 speed auto rev matching is also better than the 6 speed auto rev matching. It is still very different from the 8 speed AISIN in my RCF where the torque converter completely is locked out in manual mode and also software tuning is a lot more aggressive/faster and the gearing is different. Still the 8 speed in the RWD IS350 (or RX350 F-Sport AWD) is geared more optimally to work with the powerband, From my experience, the 6 speed auto is geared too long. In a 1/4 mile acceleration, their test numbers seem to be nearly identical of around 13.9 - 14.0 seconds, though.
05RollaXRS (01-10-23)
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
I have owned both an AWD and RWD IS, and I agree with this summation. The 8-speed, simply put, feels more modern than the 6-speed. While it's not as snappy and smooth as a ZF, it's a lot better than anything you'll find in the average mainstream car out there, including FWD Toyota models with their 8-speeds. It'll let you bang off the rev limiter if traction is fully off, which is fun, and if you're either in Sport mode at high RPM or Manual mode, it'll give you a little kick between shifts. The only real issue I've noticed is that it tends to stumble for a couple of minutes in cold weather on a cold start. You may experience some rev flare and less-smooth shifts on your first start of the day, but it should resolve itself after a few minutes of driving.
Thank you for both of you, I appreciate it tons believe me. I gladly don't have to worry about cold weather as I am in Miami. Don't mean to bother and maybe it is obvious, but is the feel in power difference between an is250 and a 350 that major? 250 has been the only car I have ever owned so I don't have much to compare it to.
The 8 speed in the IS350 is a traditional torque converter transmission, no dual clutch. It's smooth. however shifts are a bit slow and mushy. It's not super responsive. it's an old old transmission with dates back to the older LS.
drives cars
Yeah, it's "old" but not broken!
My only complaint with the 8sp is when you kick it over to manual, it's in 6 or 7th gear and you have to downshift multiple times if you're using the engine to slow down. Whereas in the 6sp, it automatically goes over to 4, which will immediately slow you down, and easier to go to 3 or 2 (if needed). My experience is the 8sp in the 2020 RX350 and the 6sp in my 2022 IS350 AWD.
drives cars
If I go into manual mode at lower speeds, it'll go down to 5 or 4.
You could also just shift into Sport S/S+ first, then manual... might remove a couple of the extra paddle pulls.
The fact that it was designed for an LS is a good thing in comparison to a lot of other transmissions available. For one thing, you know it'll be over-equipped for the amount of power the 350 produces. Another is that it does a pretty good job keeping the revs down when you are driving chill. It also responds in a progressive way to throttle inputs and is super smooth on take-off unlike some dual-clutch transmissions.
arentz07 (01-11-23)
ClubClub
10-19-20 09:12 PM
