Swap head unit with newer version?
Old 01-27-23 | 09:42 AM
fcpinto's Avatar
fcpinto
Default Swap head unit with newer version?
Hey guys my radio head unit on my 2014 IS needs to be replaced. The current one has a Face ID # P10433. Replacing with same ID is more expensive than newer head units with different ID’s. Will replacing head unit with different Face ID work?
Thanks for the insight,
Frank
Old 01-28-23 | 06:51 PM
Nabil3IS's Avatar
Nabil3IS
I think your referring to the physical screen. The one that displays navigation, radio, etc. If so then you aren't able to directly just swap over the newer screen (the larger one) onto it. If I remember correctly you need to have the correct radio (2017+) as well to go with the newer screen. Also I think there is an extra wire you might need but I could be wrong.
Old 01-29-23 | 08:19 AM
fcpinto's Avatar
fcpinto
Thanks, but it’s not the screen that needs replacing. It’s the main head unit just below the climate controls.
Has anyone replaced one with a different Face ID # with a newer version?
Old 05-24-24 | 06:45 PM
SlowBoy12's Avatar
SlowBoy12
9th Gear
have you tried this now?
Dondothesu
GX - 1st Gen (2003-2009)
12-18-20 02:44 AM
mkmckinley
03-18-20 09:42 AM
zeez88
12-03-19 08:09 AM
