Currently car shopping looking for any IS 2016 or newer and under ~$25k with the most important requirement for it to have Mark Levinson option have not found a single one with it. Is this not an option? Which Lexus models can I find with this option?
you typically won’t see any 300’s with the mark levinson system. they are mostly equipped on 350 f sport models that are fully loaded but you’ll definitely find one eventually!
A quick way to see, if you have interior photos, is the style of the volume and tuning *****.
The standard sound system has metallic-look volume and tuning *****.
Mark Levinson has very light aluminum control *****. They sometimes look white or off-white in photos.
These match the signature look of the control ***** on Mark Levinson audio products.
Fortunately, unlike these products, our sound systems do not command 5-figure prices.
I've definitely seen 300 models with the ML system before, but as stated prior it will mostly be on 350 models. I also think cars like the RC are more likely to have it, but there are also simply fewer RCs for sale than ISes.
wow thanks a ton, very helpful info. I've only been looking for the ML writing in front of the shifter but sometimes that area isn't photographed. I've found a couple so far by filtering for only 350's so that was helpful as well.
