Big Brakes
Personally I want solid rotors. Drilled are a waste of time on the street and a possible future fail point. I don't even want slotted.
wthrman2 (03-31-23)
Same. I had drilled rotors when I was like 19 and they cracked between every hole. When my dad and I removed them and saw the condition we were sure I was only alive because God didn't want to take me yet. We did not understand how I didn't explode a rotor while braking in So Cal traffic, they were that bad. That was the one and only time I had drilled rotors.
Looks like Tom's JPN are going to coming out with their new Brembo collaboration kit for the 500 at some point: 380mm's 6-piston https://tomscars.tomsracing.co.jp/brembo/
Also making full assortment of products for the platform:
https://global.tomsracing.co.jp/toms-lexus-is/
https://www.tomsracing.co.jp/sv/phot...es/IS_2021.pdf
https://completecar.tomsracing.co.jp...letecar/is300/
Hopefully Apex'i can get distribution of all the parts.
I'm more interested in upgraded pads and then putting in some upgraded brake fluid like Motul, etc. Doing that to my Supra was all I needed to make it happy on the track.
jororo (03-31-23)
Seems like this will probably be the most cost effective and "effective braking" upgrade as well. Maybe if Girodisc can make 2-piece rotors, pads + fluids should make for decent uprated stopping power.
