IS-F Front Calipers
06-23-24, 07:38 AM
Quote:
Originally Posted by
AmbyBomb
Has anybody tried fitting these behind 18s? The ISF can run 18s but I'm not sure if the fitment would be the same on our cars.
Yes the stock F Sport wheels fit.
06-23-24, 09:11 AM
OK so presumably aftermarket wheels that fit an ISF will also fit with this setup.
06-30-24, 12:21 PM
Does anyone have torque specs for the bolts that need to be removed and reinstalled when installing the calibers?
06-30-24, 01:52 PM
06-30-24, 01:58 PM
BChoCRNA
58 ft*Lbs for caliper mounting bolts
22 ft*Lbs for bridge bolt
06-30-24, 02:31 PM
Srd555
thank you so much!
Do you have access to tech stream?
06-30-24, 02:39 PM
BChoCRNA
thank you so much!
I registered
Here for 2 days ($25)
ItsFredoB
Suspension and Brakes
05-16-24 11:11 AM
Uert
02-22-19 10:19 PM
Emprado
IS F (2008-2014)
12-24-15 06:05 AM
TOMMYPHAM
06-19-13 01:22 PM
gs350RWD
06-14-13 06:13 PM
