IS500 Jacking Points for Quickjack
I made completely unscientific eyeball measurements, so I am not surprised they are off from the diagram. The track width on the IS500 is about 62" front and 63" rear, so a rough 65" seemed within the margin of error. As for the front-to-back measurement, I wonder if that is the minimum distance between the welds. If each pinch weld was about 5" long, that would make the outside measurement about 72" front to back.
My concern doing a side-to-side lift would be the quick jack interfering with work along the car's centerline.
In addition to this concern, I am not too comfortable with the prospect of lifting my car laterally - I do have another vehicle to my left and the wall to my right. When I park in my garage, I have ample walking space (about 3/4s of the distance of a full open door). How much will the lifted car travel laterally?
7000 and Extension
The 7000 by it self doesn’t work for our jack point spacing and the extension adds additional vertical space so it will not fit under our cars with the rubber blocks. See picks. If I can find lower profile rubber blocks, it will fit under the car, but you need a some vertical spacing between the QJ and the car to allow the QJ to pressurize. I don’t think there will be enough spacing. Yes, I know she is filthy…need a good wash this weekend, but it will be raining all weekend long.
Just made it under the back side
The front is a no go..
There is not enough space between the underbody and the QJ to sneak the rubber pads into position. I ended up ripping to height and length some soft wood that I had around. There is just enough space that the QJ doesn’t touch my CF sides.
Final wood pad cut
Wood pad height
Final wood pad cut
Wood pad height
Final wood pad cut
Wood pad height
Final wood pad cut
Wood pad height
Choccy
IS F (2008-2014)
12-20-21 10:23 AM
LOTC
15
07-09-01 05:24 PM
