Side skirt damage
Side skirt damage
I was washing my car yesterday and I noticed a small dent close to the rocker panel on the side skirt. This looks to be damage somehow but barely any paint abraision. It could be from a lift but there is a minor scratch from the side. My question is - the side skirt piece, this is plastic right? This isn’t considered a dent in the frame/rocker panel. The rocker panel and everything doesn’t look to appear dented below, and the opposite side doesn’t have any damage. Driver side rear passenger area
It potentially could be a lift but is it close to the lift points? The fact it is scratched a bit, i am more inclined to think you drove over something or a road debris flew from under and whacked it.
I could be wrong, and sorry if i am, but didnt you have a damaged skirt on your white lexus before? Unless i am mixing you with another forum member
As arentz said, it can be replaced as i doubt it can be repaired (at least for cheaper than buying a new piece)
HighRevs (09-04-23)
I didn’t realize rocker panels were this weird
The lift area can be seen underneath by looling where the pinch welds are, and if you look under the car, you will see them easily because there will be cut outs on the bottom of the sideskirts. They really stand out....
You really need to be careful when you use a floor jack that you position it properly that it doesnt press against the skirt as you lift the car
wthrman2 (08-07-23)
My detailer said lift damage after finally dropping the car to him. The part is loose and he’s like god no that could be from me hitting something.
does anyone know where I can find the part number?
