Triplebeam headlights, not that great.
#46
It's in the hole closer to the fender. It's kind of a pain to properly find the screw down there too, just sticking the screwdriver in there I wasn't able to find it easily. Ended up shining a flashlight around until I could see the screw on the back of the headlight through the hole and then carefully feeding the screwdriver down to it.
#47
Yeah, the manual is entirely unclear about that, which is kind of annoying lol. It just tells you to turn it the same number of turns as the one towards the centerline of the headlight, but I was able to confirm by making markings on my garage wall and then turning the screw that it is indeed the left and right adjustment.
#48
I think I will just go back in and lower then maybe half a revolution. Should be good until I can spend some time at night working on them this weekend.
If I get the lights sorted and the tires/brakes upgraded all my major annoyances will be solved with this car. Then maybe I won't buy a C8 lol. It's only $65 more a month!
#49
I had to adjust mine upward with a 12” Phillips. Once adjusted they are very good. Factory setting is so low it makes it extremely hard to see at night. I’d imagine it’s due to the car sitting so low that moving upward is angling up in the line of sight and possibly blinding for oncoming traffic. I haven’t been flashed yet.
drox
NX - 2nd Gen (2022-current)
05-15-23 01:51 PM
