Power Folding Mirrors
What do you mean by reverse scroll mirrors? Do you mean mirrors that adjust position when you put the car in reverse?
RussellTeo (07-27-24)
OK, got it. As for the mirror memory for the reverse positions, set it while in reverse and it will remember it. Have either Left or Right mirror buttons (does not matter which) in the on position and it will activate. If both Left or Right are off it will not go into the reverse position. Using one of your three memory slots is not needed for memory in reverse.
The following 3 users liked this post by Bechtold:
One thing I wish it had
Bechtold (10-23-23)
The three main options I would have liked to see are:
1. Power folding mirrors
2. Power lifting/closing trunk
3. Smart Access on the rear doors too
The following 5 users liked this post by Benibiker1558:
BChoCRNA (10-24-23),
OCJACKAL (12-31-23),
RussellTeo (07-27-24),
TipsyTonio (10-24-23),
wfibear (10-23-23)
The following 2 users liked this post by OCJACKAL:
Pandonsf (02-10-24),
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
The car was already prewire via the door harnesses. The biggest thing I noted that the mirror harness had two missing wires, where the rest of world (ROW) had all the pins filled on the mirror harnesses... I got two complete mirror assemblies and a new mirror control switch for the driver side.
Plugged everything in and when I push the button for the fold in mirrors they fold in/fold out. The AUTO button does not work or do anything. This is because there is no option even looking within Techstream to program this. I am assuming that someone from Lexus would have to flash something on the car in order to have that feature work, I've yet to find anyone / place able to do so. As it sits I actually don't need the mirrors to fold in and out as I lock/unlock the car. I prefer the manual button to fold them in. I say this because I retrofitted power folding mirrors on my w211 Mercedes and after time read many stories of the wires eventually breaking off because of the constant fold/unfolding when people lock/unlock the car. So I actually turned that feature off on the MB, and do the same exact thing. When I want the mirrors folded in, I push the button.
With the IS500, I can't image the wiring not already being there in the door... As long as you get the correct mirrors with the same options and a new window switch for the driver side I would image they would work.
This was not a cheap mod at all for the RCF. I think I paid $4500 total which included shipping and custom fees from Norway, on where I bought everything.
I'm trying to add power folding mirrors to my CT200h, and I'm fairly certain the wiring is not already there. I have a 9 pin mirror harness and everything I've researched that has power folding mirrors is 11. Whether the two extra wires goes to a control module or the mirrors, I really don't know. I'm in the process of buying a bunch of stuff and testing it out. No one has retro-fitted power folding mirrors on that platform here in the states. My ct200h is a 2016. The newer models should be easier.
Again, why the ROW gets power folding mirrors and some lexus models don't is mind boggling to me. Every lexus should. When you can buy a cheap toyota for $30k and it has power folding mirrors it's ridic that this isn't a standard option on every Lexus....
-Nigel
The following 4 users liked this post by nigel821:
I did the power folding retro fit on my 2020 RCF. RCF's in the USA did not get power folding reason for some silly reason. Lexus is so odd with options, it's ridic.
-Nigel
-Nigel
