IS 500 Threads Conversations specifically about the 2022+ IS500 models.
Installed power folding mirrors
Old 01-29-24, 11:00 AM
Pittsy
Pittsy's Avatar
Just watched the vids. Guess it doesn’t function like OEM?
when in auto mode, they should fold when locked. Unfold when unlocked.
Old 01-29-24, 11:01 AM
cp2
cp2's Avatar
not sure about the jdm/oem p/n for the actual mirrors, but you'd need a VIN to research. i'm sure an oem switch from either RX, ES, or what ever lexus model that has the mirror button included will work.
Old 01-29-24, 11:20 AM
cp2
cp2's Avatar
so on vehicles that have this function, it can be set up in auto or manual mode. if the auto is selected, the mirrors will fold/unfold when locking/unlocking the vehicle. if the button is deselected, then the mirrors will stay out (unfolded). in the video posted, it looks like the mirrors moved upon applying accessories power; unsure if the actual button was pushed. if it was in auto, then the mirrors should've unfolded when unlocked regardless of acc power.
Old 01-29-24, 08:00 PM
OCJACKAL
OCJACKAL's Avatar
Originally Posted by marjenmill
Great find and write up...thanks. Makes sense to have the driver's side mirror plug into the new switch. What does the passenger side mirror plug into to enable the folding?
i just plugged it into the same plug the passenger side original mirror was plugged into and it worked..
Old 01-29-24, 08:08 PM
OCJACKAL
OCJACKAL's Avatar
Ok I did some more investigating.. looks like the actual mirror mount is different the only way to swap out the mount is to basically cut the wires and solder them back together..
you can see the holes dont line up which means I cant use the original mirror outer cover that came with my car.. I can only use the covers that came on the mirrors I got from Japan, which I think is why the angle is off a little bit
Old 01-30-24, 06:54 AM
MYIS500
MYIS500's Avatar
Great work regardless. Pretty cool you got this done! Maybe a little time away to clear your head from it and you will be able to figure something out.
OCJACKAL (01-30-24)
Old 01-30-24, 03:55 PM
BChoCRNA
BChoCRNA's Avatar
Nice write up! Thanks for being the first to do this!
I wonder if we can use the OEM RX window switch in lieu of the IS window switch. Looking at the switch the board looks almost identical.
840A0-53020
https://www.ebay.com/itm/13471620902...mis&media=COPY
Old 01-30-24, 04:45 PM
OCJACKAL
OCJACKAL's Avatar
I think you are correct.. I thought you might have been mistaken, but when I went back and looked at the switch of the 2023 IS500 Japan, I saw the switch indeed does have the auto fold button which would make what you said very likely. lol
it was from this post....
https://www.clublexus.com/forums/is-...apan-info.html
Old 02-02-24, 08:44 PM
OCJACKAL
OCJACKAL's Avatar
you my friend was correct. I figured it out.. I had to completely swap part of the internal portion of the mirror and then use the outer portion of the came with the car originally. the only thing is the driver side doesn't fold quite as far as the passenger, but Its not noticeable according to my wife. lol
The following 4 users liked this post by OCJACKAL:
Benibiker1558 (02-05-24), MYIS500 (02-03-24), Pandonsf (02-02-24), Racer00J (07-11-24)
Old 02-03-24, 03:02 AM
DLPTony
DLPTony's Avatar
Received 4,099 Likes on 1,899 Posts
This. Is. Amazing!!
As much as I hate not having folding mirrors, I’ll never do this on my own. My dad is a master electrician, Tony on the other hand…is not. 🤣 I’d end up with ‘extra’ screws and crossed wires.
The following 3 users liked this post by DLPTony:
MYIS500 (02-03-24), phoenix888 (02-13-24), Vindahawk4 (02-04-24)
Old 02-05-24, 01:34 PM
Benibiker1558
Benibiker1558's Avatar
That shopping cart is making me nervous !
The following 2 users liked this post by Benibiker1558:
TCM55 (02-05-24), Vindahawk4 (05-17-24)
Old 02-12-24, 08:35 PM
OCJACKAL
OCJACKAL's Avatar
Spoiler
Apparently not all cars have the mirrors fold the same distance for passenger and driver side. Not that there is much I can do about it anyway. lol.. at least I haven't figured anything out yet.
Last edited by arentz07; 02-13-24 at 05:24 AM. Reason: spoiler tag because that's a lot of images
Old 02-17-24, 04:24 PM
carlosclarkmd
carlosclarkmd's Avatar
I would love to have this done to mine but I would have to hire this out. I'd likely screw something up cosmetically. I'm good with wiring and such but having to take the door panel off scares me. Do you know if you have to paint your new mirrors? Matching the iridium could be an issue...
Old 02-17-24, 04:28 PM
OCJACKAL
OCJACKAL's Avatar
Smile
It wasn't to difficult honestly.. You wouldn't need to paint the mirrors because you can swap the housings like I did.. If you buy them from Japan the angles will be off anyway and you will have to swap some of the insides of the mirror if you want to use your original housing that matches your car...
I got lucky they matched to start, but it didnt matter in the end cause I had to swap to my housings anyway in order to get the proper angles so I can see the entire lanes on the driver and passenger sides..
I hope that helps lol
carlosclarkmd (02-17-24)
Old 02-20-24, 02:45 PM
specONE
specONE's Avatar
Does anyone have part numbers for the OEM folding mirrors from Japan?
can an OEM window switch be used?
Japan spec OEM switch will be RHD though.
Quick Reply: Installed power folding mirrors
