Others having paint issues?
Noticing a couple spots where the paint’s clear coat appears to already be giving way, particularly on the hood in two spots close to each other (circled in yellow on photos below).
Anyone else having these issues? Car is garage parked and has never had bird droppings or the like on it, and at worst only sees touchless car washes. Oddest part is these are areas nobody would ever touch but it looks and feels like somebody else put their thumbs on the clear coat before it dried.
Yikes!!
No mine looks fine. Have you clayed the car before? Or used a different type of abrasive?
Having a similar issue on the fuel door, which I’ve very much touched but is same kind of clear coat failing look. Definitely need to do a complete inspection of the car now.
DLPTony (02-10-24)
I can honestly say that mine has no such issue. You gotta wonder if this is a situation where it may have been damaged at the assembly plant or while in transit and some repairs were done before reaching the dealership. These things happen and customers wouldnt even know...
DLPTony (02-10-24)
True that.
My paint is perfect, but I do get some staining on all the gloss black plastic in front, the lower side sills, and the rear diffuser after driving in the rain. I think it's from an area where new asphalt is being laid and when it rains there may be some chemicals floating on the road. It's not doing anything to the paint and luckily a little wax cleans it off. Have you tried waxing your paint area?
drives cars
I have a couple of chips on my driver's side doors - one on the front and one on the rear. I honestly think the rear door is due to the fact that I had it repainted at a body shop and not of the same quality as the original paint. The front door, not sure. I've not gotten up the courage to go through with touch-up paint yet. I am afraid of making it look worse.
Do lots of manufacturers only put the metallic fleck in the clearcoat and not in the paint it self?. It makes touching up the lexus much harder to do, I find. When you add the clear coat there there is to much sparkle. Any suggestions on the best way to deal with this?. I ended up just touching up with paint and then a standard clear coat and it looked better.
drives cars
I am Ultra White. I think it is just a base white and a fleck clear coat. I much prefer all my other cars paint with a fleck base coat and a clear, clear cote. Yours must be a nightmare!.
drives cars
Here I go with my Sharpie again ... knowing most touch-ups look horrible, I used the ol trusty black Sharpie on my small chips. I just blotted the chip with the Sharpie, then waxed off the excess black Sparpie around the chip and that's it. I swear I can't find the two or three ships on my bumper anymore. It probably works well with all the paint colors except white. There's no harm done if you don't like the results, but it does an excellent job of hiding and sealing the chip as long as they're small.
And yeah, Infrared is one of those three-stage paints - base, mid, then clear coat. So it'll probably be noticeable. The issue I am having is that one of the chips is deep enough that the paint doesn't want to adhere to it nicely. I may have to just layer the primer a few times to fill in the hole... <sigh>.
