Will 19x10 with 285/3519 fit on the rear?
I need help. Will a 19x10 with 285/3519 fit on the rear and if so what offset is needed. Has anyone done this. If not can drop back to a 275 but hoping for wider rears. Changing to the Michelin 4s made a big difference from the awful Bridgestones.
depends what the offset of the rear wheel in question is... the factory BBS/Enkei is 60 if I recall correctly... if the 19x10 wheel you're looking to use has an offset of roughly 45 you "should" be fine with clearance
cflanary (03-02-24)
cflanary (03-02-24)
I run 19x10+35 rears with 275/35R19 PS4S tires. I would recommend +45 rear offsets if you want to run wider tires. You may need adjustable camber arms in the rear, I run both #1 and #2 adjustable arms in the rear and clear with my setup.
