IS 500 Threads Conversations specifically about the 2022+ IS500 models.
The V8 is back: IS 500 F SPORT Performance
Old 12-08-21, 02:05 PM
  #3706
Yaroze86
Yaroze86's Avatar
https://www.vesselfinder.com/vessels...MMSI-354591000 almost in Jacksonville
https://www.vesselfinder.com/vessels...MMSI-432629000 Close to NJ
Yaroze86 is offline
The following 4 users liked this post by Yaroze86:
Carolina50 (12-08-21), DLPTony (12-08-21), iceache925 (12-08-21), IssaV8 (12-08-21)
Old 12-08-21, 04:17 PM
  #3707
Kanpai
Kanpai's Avatar
This guy is coming to NJ: N5001295. Dealer says it will arrive by the 22nd.
Kanpai is offline
Old 12-08-21, 06:01 PM
  #3708
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
Just a heads up reminder the VIN numbers are not going to change by increments of 1..
So far the first 8 all seem to be: JTH UP1D2 (special edition trim LE)
MANUFACTURING COUNTRY
J = Japan
WORLD MANUFACTURER
T = Toyota
VEHICLE TYPE
H= Passenger Vehicle
BODY TYPE/DRIVE TYPE
U = 4 Door Sedan 2WD / special edition ?
ENGINE CODE
P = 2UR-GSE 5.0L V8
SERIES/GRADE
1 = USE30 (IS 500)
UP1D2 portrait of vehicle = Description (4DR/Sedan/Lexus IS 500 - LE)
9th character is changing as seen in this thread - Check Digit Security Code for validation.
followed by the 10th & 11th digit which are N5 -> N = 2022 / 5 = Tahara Plant
and then the last 6 of 00xxxx for sequence number.
If we see more AP1D2, it should be pointing to a regular IS 500.
Okay that was fun, enjoy!!
If someone has a better breakdown let me know
Joe Z
Joe Z is offline
The following 5 users liked this post by Joe Z:
DLPTony (12-08-21), flighthalo (12-08-21), iceache925 (12-08-21), IssaV8 (12-08-21), Shoeboy4 (12-08-21)
Old 12-08-21, 06:07 PM
  #3709
DLPTony
DLPTony's Avatar
Received 3,993 Likes on 1,844 Posts
Joe Z
Wow! Feel like I was given the decoder ring from the Honeycomb cereal box!
DLPTony is offline
The following 6 users liked this post by DLPTony:
Compromise (12-08-21), flighthalo (12-08-21), iceache925 (12-08-21), Joe Z (12-08-21), TipsyTonio (12-08-21), wthrman2 (12-08-21) and 1 others liked this post. (Show less...)
Old 12-08-21, 06:24 PM
  #3710
TipsyTonio
TipsyTonio's Avatar
Received 2,278 Likes on 1,048 Posts
J = Japan
WORLD MANUFACTURER
T = Toyota
VEHICLE TYPE
ENGINE CODE
P = 2UR-GSE 5.0L V8
SERIES/GRADE
1 = USE30 (IS 500)
UP1D2 portrait of vehicle = Description (4DR/Sedan/Lexus IS 500)
Joe Z
I could be entirely wrong, but I don't think the analysis for the body type and series are correct. I ordered a 2022 IS350 RWD and the first part of the vin is JTHSZ1B. The Z makes sense since its a different engine, but using your analysis my vin should theoretically be JTHUZ?? Please correct me if I'm wrong. Vins confuse me as much as UPC labels, which in case some of you didn't know, they aren't random numbers. The numbers actually make sense and they basically check one another. But anyways, I digress
TipsyTonio is offline
Old 12-08-21, 06:47 PM
  #3711
wthrman2
wthrman2's Avatar
Received 3,692 Likes on 1,785 Posts
ENGINE CODE
P = 2UR-GSE 5.0L V8
SERIES/GRADE
1 = USE30 (IS 500)
Hey Joe, not trying to poke holes in your theory but if the U in the UP1D2 is the Body Type/Drive train (4 door sedan 2WD), why would the regular IS 500 (non LE) would be any different? In other words, what would be the A if the U is a 4 door sedan 2WD? The non-LE would be the same body type/drivetrain no?
Unless I misunderstood what you meant, if so, I apologize for creating confusion....
wthrman2 is offline
Old 12-08-21, 06:54 PM
  #3712
Joe Z
Joe Z's Avatar
Lightbulb
The UP1D2 I do believe is the desc for the IS 500 special trim aka “ Launch Edition “
and AP1D2 should be for regular IS 500 base trim
The desc for your JTHSZ1B2 is for an IS 350 RWD and I found a JTHGZ1B2 for an IS 350 AWD
The middle 5 are called “Portrait / Vehicle Description”
Joe Z
Joe Z is offline
The following 3 users liked this post by Joe Z:
iceache925 (12-08-21), IssaV8 (12-08-21), wthrman2 (12-08-21)
Old 12-09-21, 05:18 AM
  #3713
Yaroze86
Yaroze86's Avatar
That a LE or other?
Yaroze86 is offline
Old 12-09-21, 06:30 AM
  #3714
kittens
kittens's Avatar
I found a few on CarGurus looks like they are all LE's so far
kittens is offline
Old 12-09-21, 06:59 AM
  #3715
Carolina50
Carolina50's Avatar
Here are 2 more LEs coming into Charlotte, NC. Not sure if the one going to Northlake has a buyer yet, but that was the one I was offered.
New Lexus Inventory in Charlotte | ES, GS, GX, IS, LC, LX, NX, RC, RX, UX (hendricklexuscharlotte.com)
Carolina50 is offline
Old 12-09-21, 07:00 AM
  #3716
Yaroze86
Yaroze86's Avatar
Added to the list.
Just found maybe our #1 or 500!!! JTHUP1D26N5001001
JTHUP1D28N5000500 and JTHUP1D25N5000499 and JTHUP1D21N5000001 appear to be a valid VIN...... At this point who knows....
Current known LE's (43)
JTHUP1D24N5001143 N5001177 N5001191 N5001202 N5001203 N5001204 JTHUP1D29N5001218 JTHUP1D27N5001220 JTHUP1D2XN5001244 N5001248 JTHUP1D24N5001255 N5001261 JTHUP1D25N5001264 N5001285 N5001288 N5001290 N5001295 N5001319 JTHUP1D20N5001320 N5001321 N5001346 N5001348 N5001351 N5001367 N5001369 N5001376 N5001377 N5001379 N5001380 JTHUP1D22N5001383 N5001387 N5001391 N5001425 JTHUP1D20N5001477 JTHUP1D24N5001482 JTHUP1D23N5001487 N5001596 JTHUP1D23N5001599 JTHUP1D25N5001605 N5001620 JTHUP1D2XN5001678 JTHUP1D2XN5001681 N5001684 N5001690
Yaroze86 is offline
Carolina50 (12-09-21)
Old 12-09-21, 07:18 AM
  #3717
drawg22
drawg22's Avatar
You can add mine too (001592) that's an LE. Mine is showing to arrive into Long Beach on 12/14. At least that's what my dealer says. BTW, I was able to get mine in southern Houston and will have a 1,000 mile drive back to Iowa. Hoping there won't be any snow in early to mid January. My guess is that it will take approximately 3 weeks to get to the dealer from the port. Anyone know otherwise?
drawg22 is offline
Old 12-09-21, 07:22 AM
  #3718
Joe Z
Joe Z's Avatar
Question
Originally Posted by Yaroze86
That a LE or other?
Added to the list.
So far the lowest VIN but don't know if its a LE or Premium.
Have you read my posts ?
Joe Z
Joe Z is offline
Old 12-09-21, 07:24 AM
  #3719
Yaroze86
Yaroze86's Avatar
Just found this one! JTHUP1D24N5001000 Wonder if this is number 1 or if it's a preproduction?
Weird, just found this one is a working VIN as well..... JTHUP1D23N5000999
JTHUP1D27N5001699 works but I went through all the check numbers for N5001700 and nothing shows up for that one.
Yaroze86 is offline
Old 12-09-21, 07:26 AM
  #3720
Yaroze86
Yaroze86's Avatar
Joe Z
I have but is there a special digit for LE vs non-LE within the VIN?
Went back and reread your post, so your saying AP1 is the non LE model vs UP1 is a LE?
Went back an this comes back as a valid VIN and its not a LE. JTHUP1D20N5001415 but JTHAP1D27N5001415 seems valid as well but no info on it.
Yaroze86 is offline
Quick Reply: The V8 is back: IS 500 F SPORT Performance
