IS500 Tire choices
#256
Probably because the only reason you normally rotate tires is because the front ones get worn out more just due to turning so you get the rears up front to equalize the wear amongst the full set of four tires. In our case the rear tires don't get worn out excessively just driving straight since they don't turn so no point in rotating them. This makes you ask why even swap the fronts if both tires are being worn out the same just by turning... unless you tend to turn more in one direction .
#257
In a FWD car I would go through tires quicker in the front if it wasn't for the fact it was a square setup so I could rotate. Every RWD car I have had is staggered otherwise the same would be true but for the rear tires. My Supra could easily go through two pairs of tires for every front if all I did was just floor it and let the torque eat up the tires. Track days or spirited "Canyon runs" though help to wear down the fronts in this case through not quite as quickly as the rears. It is often close enough for me to say replace all four, especially if I am looking at a different tire altogether. I imagine the traction control though does help to reign in the rear tire wear a bit on the Lexus. I turn off the traction control on the Supra because it is a 90's paranoid system, sensing danger when none exists which is quite annoying and unexpected. With it off the rear tires on the Supra are free to wear as quickly as intended.
arentz07 (09-05-23)
#258
drives cars
#259
#262
drives cars
#267
drives cars
I think narrower is usually better for winter, especially for snow driving. Maybe a 255/40R19? That would probably work. It would be 2.7% taller, but if being slightly taller is the goal, it would be a little smaller than 265/40R19. I would personally do that instead of going 265.
snowyblue (09-08-23)
#268
Thanks for all the input. I was planning to just use my stock wheels for the winter and since stock size winter tires are impossible to find I am exploring other options. I just don't want my rolling diameter to be off by too much but perhaps a square setup of 245/40 would be okay? Again not a tire expert
#269
drives cars
#270
For those of you that haven't swapped to the Michelin Pilot Sport 4s (Summer) tires here is a short clip of my car. The traction control is off & it was around 60 degrees clear night. The car loves to hook!
