IS 500 Threads Conversations specifically about the 2022+ IS500 models.
IS 500 - CEL problem and update
Old 02-22-22, 02:14 PM
  #376
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Exclamation
Originally Posted by Moonman89
My CEL came on at 832 miles but went away on it's own without taking the car to the dealer around 880 miles. Currently at 1,300 miles no CEL. I suspect driving the car more on horrible Michigan roads & hitting bumps 90% of the time attributed to the Gasket flange getting re-aligned lol
I would strongly recommend to still have the dealership document the CEL and it’s likely stored in history..
Just because you don’t have the CEL triggering, does not mean the exhaust gasket still isn’t leaking..
The leak could still be there, but not enough to have the CEL come back.
Joe Z
Old 02-22-22, 06:57 PM
  #377
AmbyBomb
AmbyBomb's Avatar
I've put on about 450 km since the O2 sensor was replaced and the CEL hasn't returned. I assume that I've either been lucky, or the exhaust was tightened when the O2 was replaced.
The following 4 users liked this post by AmbyBomb:
Carolina50 (02-22-22), DLPTony (02-23-22), Joe Z (02-23-22), wthrman2 (02-23-22)
Old 02-24-22, 07:26 AM
  #378
18borat
18borat's Avatar
Just an update from me guys, my CEL came on when the car had 80kms on the odo. Car went to get fixed at 550km.
At first the service advisor changed the O2 sensor despite me telling him atleast 10 times to look at the flange seals instead. But guy knew better so I had him go with his fix. CEL came on within 50kms on the way back. Apologized a lot for not listening to me earlier and changed both flange seals on one go the next time.
I am at 4000km now, no CEL so far.
The following 7 users liked this post by 18borat:
AJinDFW (02-24-22), Carolina50 (02-24-22), drawg22 (02-24-22), ICEforever (02-24-22), Joe Z (02-24-22), TipsyTonio (02-24-22), wthrman2 (02-24-22) and 2 others liked this post. (Show less...)
Old 02-24-22, 07:50 AM
  #379
macmaster
macmaster's Avatar
Received 1,957 Likes on 1,048 Posts
I think a required qualification for a Toyota/Lexus master tech is to be as stubborn and self-absorbed as possible. I don't know, I've never read the exact job posting, but they never seem to want to take advice from anyone. When I first had the CEL at the time we all thought it was the O2 sensor too. I asked the master tech to check that out and the service department's response was basically "no thanks, we'll diagnose the vehicle ourselves." Lo and behold he found the issue brilliantly via the exhaust.
If you tell them the sky is blue, they'll tell you its red.
Going forward I would strongly suggest telling the techs to replace the O2 sensor. That way they'll say no and checkout the exhaust instead. LOL.
Old 02-24-22, 08:29 AM
  #380
wthrman2
wthrman2's Avatar
Received 3,692 Likes on 1,785 Posts
I agree, the dealer has to follow the direction from Lexus to perform repairs, but I am just surprised that given the amount of documented success on these gaskets that Lexus hasn't issued a TSB on it by now, I mean it seems that this fixes 95% of the reported cases (on the forum anyway).
On a side note, if I tell them the sky will be blue, they better listen because that will be a battle they will lose (LMAO) - In the tradition of DLPTony, #Don't question the wthrman (LMAO)
DLPTony (02-24-22)
Old 02-24-22, 10:59 AM
  #381
AmbyBomb
AmbyBomb's Avatar
CEL came back for me after about 450 km of no CEL driving.
The following 2 users liked this post by AmbyBomb:
macmaster (02-24-22), wthrman2 (02-24-22)
Old 02-24-22, 04:46 PM
  #382
Joe Z
Joe Z's Avatar
Exclamation
Eventually they will issue an LSB hopefully… “Lexus Service Bulletin”
@AmbyBomb did they ever replace the gaskets as that is likely the root cause..
The O2 sensor was never really the issue….
Joe Z
wthrman2 (02-24-22)
Old 02-24-22, 04:48 PM
  #383
AmbyBomb
AmbyBomb's Avatar
They didn't. They've ordered it but no ETA.
Old 02-24-22, 05:02 PM
  #384
Joe Z
Joe Z's Avatar
Red face
Silly move by them… That was the root cause and the leak triggered P013A for the O2 sensor..
It is also easier and more cost effective to go with the gaskets 1st.
Make sure you ask them to replace both gaskets… As they are one time use crush gaskets if they don’t know
Joe Z
Brandonfu (02-24-22)
Old 02-24-22, 05:03 PM
  #385
AmbyBomb
AmbyBomb's Avatar
Unfortunately they only had one gasket in stock so it wasn't an option when they replaced the O2.
Old 02-24-22, 07:27 PM
  #386
DLPTony
DLPTony's Avatar
Received 3,993 Likes on 1,844 Posts
BWAHAHA! I know better, everyone else ‘better recognize’. 😂
wthrman2 (02-25-22)
Old 02-26-22, 11:25 AM
  #387
macmaster
macmaster's Avatar
I drove 15 min on the freeway today and when I parked I immediately noticed a pool of liquid coming from the middle of my car. Is this bad? Is it related to the exhaust and the fact my gasket was never replaced?
Old 02-26-22, 11:31 AM
  #388
Answer
Answer's Avatar
Middle could be A/C condensation related, was it hot/humid?
Does it look like water?
arentz07 (02-27-22)
Old 02-26-22, 11:36 AM
  #389
macmaster
macmaster's Avatar
its 60 degrees now and I didn’t have the AC on. I have a few errands to run and will check the next time I park. Now that I think about it it would have had to drip a lot in a short amount. Maybe it is from the last car?
Old 02-26-22, 11:37 AM
  #390
Answer
Answer's Avatar
Coud surely be yeah, check it out next time you park it.
wthrman2 (02-26-22)
Quick Reply: IS 500 - CEL problem and update
