IS 500 aftermarket exhausts
#766
#767
Wow. So tempting! I like my midpipe sound but I wouldn’t mind a little more. Afraid I’d get tired of the extra sound at some point though. Easy switch back to OEM, but $700 down the drain would be a bummer. Is that always the price “on sale” or are they really selling those marked down right now?
#769
Where are you hearing the example of Murmi's install? I see the screenshot above?
MYIS500 (07-09-23)
#771
exhaust looks and sounds great. As you were able to make the invidia axle back system work, did you also have to use a 3” flanged adapter like @Civib2 had to add to make the full cat back invidia system fit?
jororo (07-10-23)
#772
good to know IS350 has the same axle back configuration. I wonder if scuffing and painting wiht high heat paint would stick to reduce the blink factor (minus the tips)
#773
#774
if it fits an rc350 or rcf it will fit the is500 but only the axleback. The midpipe off the rcf is different .
#775
yeah. I realized many have already demonstrated that the mid-pipe is longer, but axleback's all seem to be interchangable between RC's , RC-F and IS500. in some cases tip style might be the only issue for cutouts.
#777
#779
Sponsor
Just an FYI for the IS500 guys. There is an active coupon code right now to save $150.
https://www.rr-racing.com/RR-Racing-...is5exh0002.htm
-Justin
-Justin
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#780
-Justin
-Justin
