IS500 Picture Thread
#2131
#2133
clpClegg a great brand of ceramic coat is Car Pro. Start out with a spray bottle of Reload. Its the up keep spray that keeps the finish/color popping. If you like it get it ceramic coated same mfg then the up keep willl be the reload. Great product with durability shine, does well over the ppf as well.
#2134
I'm using adams products, the protection is good I haven't been overly impressed with the shine considering its cost and application difficultly. Also haven't been able to achieve the level of hydrophobic properties I see videos of with water running off the paint leaving it almost completely dry.
The following 6 users liked this post by LH1:
arentz07 (11-18-23),
DLPTony (11-18-23),
HighRevs (11-19-23),
TGPCanada (11-18-23),
Vindahawk4 (11-19-23),
and 1 others liked this post.
#2138
CplClegg (11-18-23)
#2140
Same. But after seeing pics of it completely debadged I'm tempted to just remove them all. Only tell would be exhaust tips and exhaust note.
Bechtold (11-18-23)
The following 11 users liked this post by arentz07:
08sgmis350 (12-04-23),
95bat (11-18-23),
Bechtold (11-18-23),
CplClegg (11-21-23),
FLXYLXY (11-18-23),
and 6 others liked this post.
#2142
It was like 53 degrees today & clear sunny skies. Decided to take the car out for a spin. Also, for those of you storing your car for winter. I only keep only a quarter tank of gas. Is that a ok amount of gas? I see no point filling the tank with Shell 93 since I don't drive it anymore.
The following 3 users liked this post by Moonman89:
#2143
The more gas you put in the tank, the less air will be in the tank. So, it'll go bad more slowly if the tank is more full. You could also add some gas stabilizer if you want to be extra careful. That's all I know about it. I'll probably still drive mine occasionally if the temps are high enough.
#2144
^^ I have the Michelin Pilot Sport 4s (Summer-Tires) on the car. However, as long as it is dry & 45 degrees or above & dry pavement. I can drive it which is the plan but the next-week forecast is freezing.
#2145
