The V8 is back: IS 500 F SPORT Performance. Part 2 2022 Sales & Delivery Discussions
#271
Considering on paper the power-to-weight ratio is similar between RCF and IS500 (around 8.4 lbs/HP) while the ISF has a power-to-weight ratio is about 9.1 lbs/HP, on paper it favors the RCF or the IS500. However, it is complicated. The reason for that is, the ISF gearing overall is very different due to different wheel/tire circumference (especially for the RCF with the big 275/35/19 rear tires) and also the ~ 600 rpm higher rev range.
The RCF is geared optimally for all-out acceleration while ISF is geared optimally for the 1/4 mile because it shifts from 3rd to 4th much earlier (around 94 mph) than the RCF, which shift from 3rd to 4th about 4 - 5 mph before the 1/4 mile trap (around 110 mph). So, if that 3rd to 4th shift just before the 1/4 mile trap and have not gotten back into the "meat" of the powerband (above 6000 rpm), you easily lose a couple of tenths. An ISF would be more consistently in the "meat' of its powerband because it shifted to 4th long before the 1/4 mile trap. Not sure why Lexus had to make RCF's 3rd gear so damn tall? (it does work much better in long sweeping turns) That is why, in theory it should be close in the 1/4 mile times between an ISF and RCF. Quickest stock RCF achieved has been 12.5 seconds. People have reduced the rear tire pressures down to 27 PSI on the RCF to get the gearing shorten down, which significantly improved 1/4 mile times down to 12.3 seconds.
This video shows what I said above. the ISF and RCF stock for stock, is usually down to the launch up to 80 mph. However, that top end power and longer rev range starts to show up after 80 mph and RCF starts to pull away steadily up to 140 - 150 mph. However, once you put a few bolts on the ISF, it gets very close in a straight line. An ISF with intake/header/exhaust is considered a very close race with an RCF with a full catback exhaust in a straight line.
The following 5 users liked this post by 05RollaXRS:
arentz07 (06-01-22),
DLPTony (05-28-22),
konichiwa3 (05-27-22),
macmaster (05-27-22),
wthrman2 (05-28-22)
#272
I am sure you guys have seen that the V6 was taken out of the Highlander, now its out of the Lexus RX so we are lucky that they approved dropping the V8 in our IS and I am some glad I was able to put my hand on one more than ever....We knew it was a dying breed but when they are killing the V6, imagine how lucky we are to get a new V8!!
#273
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/312x296/dfa_0186d19088a926f70bfd3f0764e2d8e765a2f8cc.jpg)
wthrman2 (06-01-22)
#274
drives cars
Lexus IS 500 F Sport Performance:
- 5.0 V-8
- 472 horsepower
- 391 lb-ft
- 8-speed auto
- 0 to 60: low 4-second
- 2.4 turbo I-4 and hybrid
- 365 horsepower
- 406 lb-ft
- 6-speed auto
- 0 to 60: high 5-second
#275
- 5.0 V-8
- 472 horsepower
- 391 lb-ft
- 8-speed auto
- 365 horsepower
- 406 lb-ft
- 6-speed auto
No more boring cars eh Morizo?
#276
drives cars
I will try to make this as objective as possible..
#277
- 5.0 V-8
- 472 horsepower
- 391 lb-ft
- 8-speed auto
- 365 horsepower
- 406 lb-ft
- 6-speed auto
#279
wthrman2 (06-01-22)
#280
- 5.0 V-8
- 472 horsepower
- 391 lb-ft
- 8-speed auto
- 365 horsepower
- 406 lb-ft
- 6-speed auto
#282
drives cars
I wonder if it's the torque number that they're using to denote the "500". 500 Nm of torque or up?
IS 500: 391 lb-ft | 530 Nm
LS 500: 442 lb-ft | 600 Nm
RX 500h: 406 lb-ft | 550 Nm
Maybe that's not it either.
Make it make sense, Lexus!
#283
For a while, it did refer to the engine size in CCs, but that seemed to tail off. May have just ended up being a "trim level" at this point
Carolina50 (06-01-22)
#284
Maybe not making sense of it is there marketing strategy
#285
