Front Apron Separation?
#166
The poor folks in Japan are going to have to enter a lottery to get the First Edition IS500. Little do they know they're entering a lottery for a defective car, misshapen apron and all.
#167
^^ Unless they finally figure out some of these issues prior to launching it. I mean the CEL thread has been quiet lately so that is encouraging but even that one, the cause of the issue is known. I think right now, the only unresolved issue is the front apron - The fuel pump so far seems to have been limited to a single forum user so far.
#168
The following 4 users liked this post by TipsyTonio:
#169
I couldn't agree with you more!!! Let's just hope we'll be able to find out from IS 500 owners in Japan if that issue develops, and what needed to be done to fix it. As you said, these branches seem to operate in a vacuum and not cross share information. Last rumor I heard is they were going to try to glue the bumper with maple syrup up here but given how warm that part gets, I suspect it will get too runny and we'll be back at square one (lol)
The following 3 users liked this post by wthrman2:
#170
Given that the engineering team for this vehicle is likely in Japan, I suspect that if they become aware of issues on the JDM version, it is more likely to go straight to the ears of those that can fix it, versus us in North America that must first relay to Lexus USA / Canada who then needs to relay our concerns to Lexus Japan. In a way we will be circumventing the middle man.
The following 2 users liked this post by DLPTony:
TipsyTonio (07-21-22),
wthrman2 (07-21-22)
#171
I am just curious if any members have any new update to report on this issue?
#173
As we both are in the same boat with our dealership this is what I have done and also believe it might help the other IS500 owners with this issue.
I just picked up my car few hours ago for the third time and this is the latest update that I got from them.
I attached a Facebook group response where an IS500 owner is already working on getting the new bumper .
I just drove 25miles @80mph to test the adhesive and so far its holding on good. I will update if I come across the issue again.
I know it requires time and effort to put up with this issue but I personally feel its worth it for this V8 sedan .
Also kudos to the dealership for being proactive to find the cause and fix to make an IS500 owner happy.
Hope this was helpful.
- Open a case with Lexus corporate so that your case reaches your Lexus regional manager "cases are specific to region".
- Update the dealer about your open case with Lexus, So that the dealer can create a case file to track the history of the fix done so far for the vehicle and also communicate with Lexus to get the best possible solution.
- As per the body shop manager they checked every possible location to find the cause and also took images to update Lexus on their findings. They couldn't find the specific cause even after multiple tries.
- At this point Lexus has no available solution for this issue and the corporate left the repair decision to the dealer body shop experts.
- The respective bumper pins are glued to the bracket that is close to the fender as a temp solution.
- If the issues arises in future, the best possible solution will be a bumper replacement "having a case history can expedite this process but expect delays with part shortage" or reapply adhesive glue .
I drove 400miles after the adhesive repair.
So far so good. I no longer see the gap or the pins popping out.
The Lexus corporate called and confirmed that they will look into other solutions if this issue pops out again.
For now I would suggest to get the adhesive job done at the dealership under warranty including the Lexus corporate to document the temporary solution.
I will wait till the Japanese markets finds a solution for this issue.
#174
UPDATE:
so mine apparently won’t be covered under warranty because there is the ever so slightest scratch on the front left corner bottom of my front bumper. They said that that caused the large separation on the apron. What do we have to do to get this fixed under a recall?! The dealer is wanting to charge like $400 and my local body shop is about the same.
#175
Looks pretty sexy right?
You'll want to click and zoom in on this one:
#177
