IS 500 Threads Conversations specifically about the 2022+ IS500 models.
Does IS500 bounce off rev limiter like the RCF
Old 08-26-22, 06:27 PM
robjay0211
robjay0211's Avatar
Default Does IS500 bounce off rev limiter like the RCF
Can anybody confirm if the IS500 can do this?
I don’t think my 2021 IS350 can lol
Old 08-26-22, 06:32 PM
jororo
jororo's Avatar
Originally Posted by robjay0211
Example
It sure can. Didn’t like how my old IS350 auto upshifted at redline even when in manual mode. Apparently new TLX Type S auto upshifts too.
Old 08-26-22, 06:44 PM
Answer
Answer's Avatar
It'll auto upshift first to second, but it can sit on the rev limiter in all the other gears
Old 08-26-22, 06:52 PM
robjay0211
robjay0211's Avatar
Wait so does the RCF auto shift from 1st to 2nd too?
Old 08-26-22, 06:58 PM
Answer
Answer's Avatar
I cannot 100% confirm, but pretty sure yes. From the sound that one made, it really looked like it did.
Old 08-26-22, 07:09 PM
macmaster
macmaster's Avatar
Received 1,957 Likes on 1,048 Posts
The IS500 does not auto upshift from 1 to 2 in M. At least mine doesn’t
Old 08-26-22, 07:25 PM
Answer
Answer's Avatar
Have you really tried not shifting it at all in first at WOT? I did it couple times in manual mode and it always auto shifted to second gear after hitting the rev limiter.
That's has been discussed in another thread where we didn't like it because if you also shift it, you end up in third gear
Carolina50 (08-26-22)
Old 08-26-22, 07:38 PM
macmaster
macmaster's Avatar
Does yours auto shift before the redline or does it auto shift after bouncing at redline for a second?
Old 08-26-22, 08:27 PM
Renault
Renault's Avatar
In manual mode, if I go all the way with that last little bit of throttle, it will auto upshift right before redline so it won't bounce of the limiter 1st to 2nd.
Old 08-26-22, 08:58 PM
macmaster
macmaster's Avatar
what happens if you don’t go all the way with the throttle?
Old 08-26-22, 09:11 PM
jororo
jororo's Avatar
Same here. Honestly 1st & 2nd gear are only time I’ve experienced it bouncing off the limiter, timing shifts is easier in higher gears especially when transmission isn’t fully warmed up.
Old 08-26-22, 09:38 PM
macmaster
macmaster's Avatar
I don’t know what that last part of your statement means, but I agree it is easier to bounce off the limiter between 1 and 2 because my god these gears are tall. To bounce from 2 to 3 you would be going like 75-80mph I think.
Edit: exaggerating on the speed. I think it’s more like 65-70mph. In any case IMO it’s a speed that is too fast on public streets to appreciate the sound of the rev limiter, because a highway is too noisy.
Old 08-27-22, 01:44 AM
DLPTony
DLPTony's Avatar
Received 3,993 Likes on 1,844 Posts
Unpopular opinion, I’m not a fan of bouncing off the rev limiter. It means a loss of power and momentum; so if I’m revving it full out, there’s most likely a race happening. 😈
The following 4 users liked this post by DLPTony:
HydrantHunter (02-04-24), Kanpai (08-29-22), MYIS500 (02-02-24), wthrman2 (08-27-22)
Old 08-27-22, 05:05 AM
jororo
jororo's Avatar
100% agree. Every time I’ve bounced off it’s been due to manually shifting a bit too late. When the transmission is good & warm can click the paddle around 7000rpm and get a proper redline shift from 1st to 2nd, but when it’s still somewhat cool seems like you have to initiate the same shift at ~6600 rpm to get it to shift right at 7300rpn.
The following 2 users liked this post by jororo:
DLPTony (08-27-22), HydrantHunter (02-04-24)
Old 08-27-22, 07:15 AM
95bat
95bat's Avatar
Received 1,329 Likes on 681 Posts
Samesies.
I like that the car will spin the tires on the 1-2 shift when you get it just right at 7200-7300 rpm
I have never had my car auto upshift from 1-2 but I've never been late on that shift. If it isn't 100% safe to watch the RPM I will short shift 1-2 instead. I have hit the Rev limiter in other gears, but never lit it sit there for a full second though. It's usually just a hair late so it might bounce 2-3 before the shift goes through. It will shift pretty damn hard from 2-3 as well when you're at max RPM.
DLPTony (08-27-22)
Quick Reply: Does IS500 bounce off rev limiter like the RCF
