These are the stock brakes I have ever used. Do we have aftermarket/retrofit options?
wthrman2 (12-09-22)
#62
I have a 21 C63s which has steel brakes as well and that does not have any issue for the last 2 years I have been driving it. That has 30000km mileage as well compared to my IS500's 18000km. So I do not think my driving is the problem.
Both the cars have similar whp. So they should be matched by similar brakes performance from the manufacturer.
#64
Sure it's the rotors and not the driving style and/or pads?
"Warping" is not a problem with the rotor itself, in 99.9% of cases. To get a rotor hot enough to physically deform it would be near-impossible on the street. https://www.motortrend.com/how-to/18...ed-rotor-myth/
#65
drives cars
And by driven the crap out of, I mean multiple trips up to the mountains, sometimes in continuous downhill sections, accelerating up through 3rd gear and back down to 2nd before the next corner, rinse and repeat, while chasing my friends in their 500s, modified IS/GS models, and IS Fs. I smell the brakes after.
But I also have over 150 less horsepower and close to 200 pounds less weight to carry. What would be nice is if other IS 500 owners who have tracked the car or otherwise pushed it to the limits could chime in with their impressions of the brakes.
#66
Try a new pad compound.
#67
The dealerships did not swap out the brake pads though. That is still the original set. I do not know if it is a pad issue. And Lexus's brilliant customer service stops them from replacing something as cheap as pads.
Mercedes changed all four of my rotors and pads in the first few weeks of me getting the car just because I complained about minor sqealing noises at low speed without me asking a second time. I love the IS500 for what it is, but Lexus's customer service is probably one of the most horrible I have ever experienced. I told them so many times, why dont you change the pads as well to eliminate any possibilites. Nope.
#68
Looks like R1 Concepts has products listed for the IS500 (Rotors & Pads options). I have heard of R1 before a lot of RCF & GSF owners purchase their stuff.
https://www.r1concepts.com/detail_ca...ors+Front+++++
#69
^^ I am always worried to install aftermarket pads and have a crap load of brake dust. That is one thing I like about our OEM brakes, they are relatively free of dust. The question though, is the brake feel a problem with the rotors/pads or simply the way they are calibrated and would swapping automatically produce a different result?
#70
I've driven the crap out of my IS 350, which has worse brakes than the 500, and have had no fading or warping. Though I also don't hit triple-digit speeds (MPH) because I like having my driver's license and not dying to a random deer.
How sensitive are you to pulsation? I've definitely noticed very slight pulsation when coming to a stop under 20 mph with light braking that isn't noticable to me at 100 mph under heavy braking. I figure this might be due to uneven wear at the edges of the pads more than anything else (the rotors were starting to cup by 1-2mm or so when I replaced them), or otherwise just the difference between 3 and 0 thousandths.
Also comparing the IS350 to IS500 front brakes, there is so little difference in rotor or especially caliper from what I can tell. Similar 4 piston design, same size brake pad backer (they are actually interchangeable in a pinch), and maybe half an inch of extra pad contact width along the radius of the rotor entirely due to pad material shaping. The rotors are slightly larger so they may stay a little cooler.
arentz07 (06-06-23)
#71
drives cars
I've taken my 500 to Thunderhill, Laguna Seca, and Buttonwillow and haven't had issues with pulsation from rotor runout on the stock rotors (they stayed under 3 thousandths). The stock pads are incapable of more than 2 laps at any of these tracks and wore incredibly fast. The first track day wore the front pads away completely with moderate to severe brake fade as they were wearing (I wasn't able to theshold brake coming into every corner in order to keep them cool, and did cool down laps within each session). EBC Yellow pads can make it through 1.5 or 2 track days, and I probably wore 4mm away over 3 track days before replacing them. They sometimes need one cool down lap per session.
(I have traded my IS 350 for a 500 since I wrote that post.
#74
If you have $8,000 (not including shipping) burning a hole in your pocket you have two options:
- Send it to me, or
- Buy the TOMs Brembo Kit: TOMS Racing Brembo x TOMS Brake Kit - Front 6POT 380mm | Brake Kits for Lexus IS 3 Late | TOP END Motorsports
Carolina50 (06-14-23)
#75
- Send it to me, or
