Could you share with me wiring diagram of the EPB system on the '23 RCF ?
I want to review it to see how close it is to '21+ IS or 4GS system EPB system...
Shoot thanks. Looks just like how GSF is setup.
I think we can complete forget about '23 RCF as a solution at all now. (Will be a major retrofit that can be potentially done but not everyone will be willing to)
Just to double check, all is working? that's awesome!
All works fine, i am waiting on my custom built cables for the actuators to plug into so i can clear the error codes, but the brakes work well. Remember there is no solution for the EPB to function.
got these in today, really excited to get these on(should be this weekend) behind the black bbs wheels they will look so good. I did not get the rears I will wait for a solution to the epb
what pads did you get? are you going to steel brake lines?
I’m just sticking with the stock lines, after reading a lot of the posts on here it dose not seem necessary. I got the factory brakes pads, not trying to do anything aggressive with the brakes.
RCF OEM Lines or SS braided lines would definitely be a good upgrade. Your brakes will feel a lot firmer. If you ever take the car to the track or get your brakes hot doing some "spirited" driving, you run the risk of bulging a line. Granted it's a very small risk, but for how cheap lines are I would do it just for the firmer pedal.
Nice!! I got mine (front and rear) a month ago but still haven't installed them. I'll be installing just the fronts as well but I will ceramic coat them first. I got the rears just in case there will be a solution and wanted to match the fronts. lol
I forgot to mention, since its related to the brake upgrade. Did anyone figure out the right spare tire to run and clear the fronts? I was looking at RCF/GSF spare but was wondering if there is any other options that can fit in the 2021+ IS.
I just bought a spare front BBS rim to use as a spare.
