IS C Discussion about the convertible IS C model
IS350-C/IS250-C - Top info
Old 07-02-14, 07:52 AM
jgr7
jgr7's Avatar
Originally Posted by freeflight
Nice. Which dealer did you go for the repair?
Lexus of Concord
Old 07-11-14, 07:12 AM
13IS250C
13IS250C's Avatar
Originally Posted by brettno1
I own a 250c and to the best of my knowledge the car is too new to have any accurate info on reliability of the top. With respect to maintenance, there is no required or even suggested maintenance in regard to the top.
The only "maintenance" I do is to put rubber conditioner on the seals that are inbetween the roof sections. The only other maintenance that could be done is to lubricate the gears but Lexus doesn't say that it's necessary.
In a nutshell, since Lexus hasn't indicated that any maintenance is necessary, I wouldn't worry about it.
Can you please tell me what lubricant you used? I need to do the same thing. I don't want anything that is going to run down my windows every time it rains.
Old 07-13-14, 03:54 PM
Machog
Machog's Avatar
I have a 2010 IS 250 C with 30k miles on it.
About 4 months before warranty expired I got a rattle on the passenger side in the roof at the top of the window. Took it to the dealer who made some adjustments, its now 100% quiet.
He said it was a fairly common problem and easy to fix. Other than that its been just about flawless other than routine maintenance.
Machog
Old 07-15-14, 02:03 PM
fknISC808
fknISC808's Avatar
I just used White Lithium Grease on my gears and seats that were making that groaning noise. either than that, all is good here since 2009
Old 07-18-14, 09:04 AM
starryck
starryck's Avatar
Machog
My dealer said that it costs $1500 to fix - can you tell me which dealer you went to?
Thanks
Old 06-06-21, 07:29 AM
122dem
122dem's Avatar
HI,
When you applied the conditioner in between the roof section did you operate the roof to half open or ? Closed?
Thanks
Old 06-06-21, 07:30 AM
122dem
122dem's Avatar
HI,
Thanks
jagtoes
ES - 5th Gen (2007-2012)
05-30-16 09:23 AM
lexusplz
07-10-15 06:46 AM
catdaddylo
12-28-11 08:27 AM
Quick Reply: IS350-C/IS250-C - Top info
