IS C Discussion about the convertible IS C model
Questions about the top and climate control
Old 06-11-14, 09:05 PM
treead
treead's Avatar
Default Questions about the top and climate control
Does the top just stop and hold position if you let go of the button in the middle of open/close operation?
When the top is down, and you push the front defrost button, does the A/C also comes on? On my RX, the A/C always come on with defrost (even when the A/C light is off), I understand this helps defrost the front window faster. But in a convertible, I would like to have full heat towards the window in the fall. (yeah, I'm that guy in a toque with the top down, windows up while it's freezing out) Thanks.
Old 06-11-14, 10:57 PM
jgr7
jgr7's Avatar
If you stop mid way going down it will most likely slowly keep going down, so what I do is stop going down and than start going back up and it will hold. Yes the ac works the same with top up or down.
xf30ul
04-26-21 08:43 AM
Jhua
06-28-17 11:13 AM
zes
ES - 6th Gen (2013-2018)
19
04-26-17 10:57 AM
one2nite
08-17-13 06:29 PM
tacomaboy
RX - 3rd Gen (2010-2015)
17
01-08-11 09:39 PM
Quick Reply: Questions about the top and climate control
