IS350C Goes from Daily Driver to Stunning Droptop
On the accessories sideshow it appears to show a steering wheel cover in mock wood. If so, it looks better than it sounds!
Do I have this right and where is it available from?
https://www.clublexus.com/how-tos/sl...ng-wheel-cover
The steering wheel you are referring to in that slideshow is actually genuine leather and it comes from an Israeli company called Ali Express:
https://he.aliexpress.com/item/Sport...775439717.html
But there are plenty of stateside custom interior companies that cater to Lexus customers. Here's one that looks pretty good:
http://www.craftcustoms.com/photos-b...eel-dash-trim/
Once you updated the "Springs and Roll Center Adjusters" did you leave the sway bars and shocks stock?
Was the Borla a bolt on fit or did you need modification to fit over the convertible's rear axle?
Apparently I'm featured content!
To answer a couple of questions yes the factory shocks we're kept for now. The f sport springs are designed to be used with either the factory shocks or you can upgrade to the f sport shocks which I plan to do. I still have the factory sway bars. But again planning on upgrading those.
The muffler has not been fitted as I am planning to completely redo the whole catback system.
Most of this is going to happen after the first of the year.
dantampa
11-10-15 11:57 AM
bagwell
05-15-14 08:22 AM
