Is drilling required to install a windscreen?
I got a used windscreen but it came with 0 instructions. Do I first have to pull out the plastic pieces in the back seat area by the speakers? Or do I drilling into them to mount the windscreen??
https://m.youtube.com/watch?v=6XQwqYoXdGs
Also, the plastic trim pieces are impossibly tight. I used a 12 inch screw driver as well as a special trim removal tool and I couldn't get the plastic circle to pop out. Should I just put harder? I don't want to damage something.
Not sure who made that video, but that's not how the wind deflector is supposed to be installed.. Those caps should come off (not drilled into) and then a barrel (from the installation kit) gets bolted into a threaded receiver behind it. Not sure where u found this video, but I would think those caps will eventually pop off when the deflector moves around when going over bumps, etc. Or maybe not..
https://www.clublexus.com/forums/is-...tor-score.html
for black interior:
PT933-53100-HR Head rest receiver
PT933-53100-02 Windscreen plug
I just searched ebay, and you can get the plug for $14. The Head Receiver is around $30. So not reasonably priced, but not terrible, either.
Thank you! Unfortunately my used kit didn't come with anything else apart from the windscreen. Can I just order the ones with the pre dropped hole?
caddyowner
02-11-21 03:28 PM
