2010 lexus is350c roof ecu located at?
Reach out to Jeff. He may be able to help you.
https://www.clublexus.com/forums/mem...eff-lange.html
ROCKY919NC (04-22-19)
The code is for "No communication between sliding roof control ECU assembly and gateway ECU for more than 10 seconds," and can be caused by a couple of problems:
Hope that helps!
Jeff
- Sliding roof control ECU assembly
- Gateway ECU
- Wire harness or connector
Hope that helps!
Jeff
Hope that helps!
Jeff
- Gateway ECU
Hope that helps!
Jeff
How much do you think the Lexus dealership will charge to fix it ?
This is the convertible top control module, it is rather expensive.
http://www.mylparts.com/oem-parts/le...Y2LWdhcw%3D%3D
Retroplay
01-30-22 01:48 PM
