Buy Ready Painted Mirror or Have One Painted?
The driver's side mirror on my daughter's 2014 IS 250 C was whacked and needs to be replaced. I see unpainted replacements for around $100 and painted, ready to go mirrors for $400 or more.
I've also seen recommendations that I should buy the unpainted version, and take it and the car to a body shop where it can be properly color matched exactly to the car. It looks as though a paint shop will charge $200 to $300 for this. Allegedly, this is the better way to go because a 7 year old car will have experienced some fading and a mirror painted to factory paint codes won't quite match.
So...
Many thanks.
So...
- Any truth to the paint matching issues?
- Experience in doing it one way or the other?
- Recommendations for a supplier for either way?
Many thanks.
Does she drive a show car that has to be perfect? If so, the paint shop is the way to go. If she has a daily driver, then a couple of thoughts--first, if the color is slightly off, who's going to notice, and, if they do, what are they going to say? Second, it is always possible to paint the mirrors a complimenting color as is your grill or wheels and can be done with a spray can. (I've used them to where only an expert would notice.)
And you can always get matching paint from a company on line that makes those colors in a spray can. Then coat it with a clear coat to have the same shine. Since the mirror is at a different angle from the body and pillar, it will always look slightly different due to the light angle from the sun anyway.
I've used color matched paint and clear coat on my motorcycle fender in the past... I'm not much of an artiste, I have learned... but perhaps for such a small piece, I could make a good job of it.
Your comments about painting also remind me that I'd need to remove most everything (puddle light, signal, etc) to get the best spray job done. Perhaps painting at a shop would be cheaper if they only had the mirror casing to deal with.
Damaged how is the mirror just swiveling on its own? I'm assuming the cover just got damaged?
There is a fix for the swiveling mirror. It requires some force. Two people would be best.
If just the covers. You can buy them from bell lexus in Arizona. I actually purchased a set from them weeks ago. Covers already come painted. They run about $70-$80 each.
Schris22
09-23-05 03:32 PM
