Isf ecu swap
Isf ecu swap
My TCM Went out on my 09 ISF that part is now discontinued 89535-53040, Will i be able to swap another year ISF TCM in i don’t know if they are superseded part they other tcm’s have the same part code and same part number just 2 digit’s different at the end. The Engine control module’s on the other hand are supersession’s I look at lexus parts now and it says “Replaced by” but it doesn’t say it for the TCM only the ECU For example if i swap a 2010 TCM into my 2009 ISF will it work? or will i need a 2010 ECU and a 2010 TCM to make it all work. Its all very confusing. Are all ISF’s pretty identical in terms of harness’s and hopefully this will be plug and play
Thank you
Thank you
See this thread:
https://www.clublexus.com/forums/is-...ode-u0101.html
Edit:
Well - I guess you already did
Edit:
RJMacReady (09-13-24)
Nigel-JDMParts
IS F (2008-2014)
262
05-24-14 02:53 PM
