F runs terrible after an oil change, everytime
#46
2011 with 101k miles here.
#48
I'm at about 300 miles and no improvement, I'd actually say it's been the worst today. Those experiencing the issue, how are your LTFTs? Mine have been settling in the -20 range, both banks. STFT are fine when accelerating and idling but freak out at low throttle, causing the KCLV to crash.
#49
That could possibly be a tune issue unless its something that just popped up. The first tune file I got from RR for the tuned intake (larger maf) wasnt calibrated properly and i saw -20 LTFT (fixed quickly with a new file). I would double check with Loi and make sure you have the right tune file for whichever MAF housing you're running (stock/mrp/rr).
Also look for any intake/vacuum leaks, especially around the MAF. You mentioned oil change, and the hoses that go into the HPS intake are pulling some vacuum on the crankcase. So any leak at the oil cap, dipstick tube, valve cover gaskets, aos etc could end up as unmetered air into the cylinders.
inovashn (11-10-23)
#51
SoulFreak (11-13-23)
#53
Tech Info Resource
This is what Toyota says about LTFT, STFT, and Vf. These are all important parameters for fuel trim.
The following 3 users liked this post by lobuxracer:
#54
I smoke tested for vacuum leaks this weekend and found a small leak at the intake elbow to throttle body connection. I got it sealed up and my car is seemingly back to normal (fingers crossed).
The following 4 users liked this post by footballpl:
#55
I'm seeing a similar issue on a 2017 GS-F, bone stock. I did use Amsoil 5W-30 which was mentioned here. Filled the oil level all the way to full, but not over.
Resolved it by disconnecting the intake elbow and re-seating the air filter. I suppose it could have been a leak like the poster above, but wouldn't it have experienced the issue before the oil change?
From my thread:
https://www.clublexus.com/forums/gs-...il-change.html
From my thread:
I just changed the oil for the first time after buying my GS-F. I drove it for about 3 days but it just didn't feel the same. Power levels felt like maybe 75% of normal. No lights or warnings - nothing. Oil level perfect.
I got the idea to check on the air filter, so I disconnected the MAF and opened the box, re-seated the filter, and connected everything back up. The car ran 100% back to normal after that.
I'm stumped that opening and closing the filter enclosure like that would make any difference. During the oil change, I didn't touch the intake or anything connected to it at all.
Has anybody else experienced this strange behavior?
#56
A not-uncommon problem with the LS460 too.
Mine would do it with every oil change, KCLV would drop from about 28 to 4 or less after each oil change.
I’m a bit disappointed to see some ISF suffer the same fate.
#57
2nd ISF here…
I have never had these issues you describe. Are you sure the mechanics know how much oil this engine takes ? Every mechanic I tell looks at me funny. Get the filter from Lexus parts 2 5q jugs of oil from Walmart and either DIY or bring to oil guy . Half the beauty of this engine is we can work on it ourselves. Who do you trust more ? A oil change guy or yourself? If they were mechanics they’d be at a shop not in a trench . But sorry to hear this about your car to be honest hopefully you got it down pat. Luck
#58
1) monitor the KFV and KCLV after the oil change, if knock feedback drops below 4.5, lift off the throttle (the ECU seems to need to see sustained ‘knock’ to pull KCLV).
2) Drive in a manner that raises KCLV. In the ISF people put it in 8th (?) and floor it. In my LS460 I would accelerate super gently from 0-100 (km/h) and could get KCLV back up close to normal within an hour of driving.
#59
You must be past this now, but next oil change you can do two things.
