F runs terrible after an oil change, everytime
I can’t be the only one. This has been consistent with every oil change. I get a low load knock at 1% to 3% throttle input maintaining speed, knock sensors go crazy but only after an oil change! Come to find out that the 2UR does not like to be filled past the halfway mark between low and full on the dipstick, otherwise the engine consumes oil and creates knock, however…. every oil change lately no matter where the level is at the knock sensors go off the richter scale rendering the car nearly useless to drive, seems to be getting worse. My oil is not overfull, my aos is empty, and there is no vacuum leaks (though it acts like one) nothing else was touched besides a simple oil and filter change. Personally don’t believe it is tune related. After 200-300 miles car slowly snaps out if it and runs like crazy. Amsoil signature 5-30
I want to understand why new oil is creating knock/detonation it should be the opposite
Tech Info Resource
This has not been my experience with either of my F cars.
The same thing started happening to mine three intervals ago. I noticed it right away when I switched from redline to Renewable Lubricants. I just changed the oil two weeks ago. Same thing. I been extremely meticulous with the oil level. Looking back at the history I noticed The Valley plate was resealed at 69k miles. I’m at 86k miles now. Changing oil between 3-4K miles. The only thing I can think of is the knock sensors were messed with during valley plate job. My KCLV will dip into single digits. Then slowly climb back up.
dcguy (04-15-23)
dcguy (04-15-23)
Yeah, there has to be more out there but very few, Ive had others locally that have had the same issue but was resolved by filling the oil less than 3/4 or close to 1/2 from full on the stick. Also to mention with headers if the dipstick was modified it could result in an improper reading. Another on facebook mentioned he had the same issue when using amsoil but went back to mobil 1 and hasnt happened since. So this may be an oil type thing as well
lobuxracer (04-16-23)
Absolutely not resetting ECU or disconnecting battery at all. As a matter of fact when you reset ecu KCLV defaults to 15. What I’m experiencing it’s KCLV levels in single digits & slowly climb back up to 20-22. Correct, 5w-30. Agreed, it doesn’t make sense. This only happens during oil change.
This is baffling to say the least🤔
Mine has been doing this for a while now, however oil level or changing oil doesn't seem to have any effect on its presence. My KCLV can get up to 24.5 and can drop to ~19
I haven't really been able to pinpoint any specific scenario that causes it, I do believe its more prevalent after a left hand turn for whatever that's worth.
I use renewable lubricants 5w30, I have done the valley plate and i had to replace a knock sensor due to the leak, rr tuned but i see this behavior on the stock tune as well
I'm curious if you've also been monitoring misfires? Another thing mine does is show misfires on random cylinders but they never trigger a CEL
The following 2 users liked this post by 93MSB:
dcguy (04-17-23),
MileHIFcar (04-17-23)
I have OBD Fusion, can you monitor misfires with the app? If so how? I been wondering about misfires, during my idle I can hear what I think it’s misfiring. I changed my OEM plugs recently with brand new OEM ones. It’s still doing the same thing. No CELs. I just have QES exhaust. And I can hear the tone change during idle. It’s a subtle popping sound, not very prevalent but I can hear it change.
Soulfreak add a digital display its under the add-on of toyota/lexus/scion > engine > total misfire count from there i suppose we could add all 8 cylinders and single some out but have a feeling it would be random
Tech Info Resource
How many of the problem cars have an AOS?
