ISF Weird Noise
ISF Weird Noise
Looking for some help with a weird noise before I end up having to take it to the dealer. Appears to be coming from below the front passenger and driver footwell. Sounds like a busted speaker (Radio is off). More prominent at 40-50mph. Car runs smoothly, and idles smoothly. The noise is not present at idle at all. Makes me think it is something with the suspension but I can push down on the car in the driveway and it is silent. Everything underneath is tight.
Any suggestions on what to look for? Thanks.
It sounds like some of the plastic paneling below is flapping around when you increase the wind speed under your car. Of course when you look under it, everything probably looks fine. Would put the car up on jackstands or a lift and inspect the bottom. Perhaps take a video underneath it at speed to see if somethings flopping around. Doesn’t sound mechanical but could be wrong
I checked every panel under the car. Nothing is lose. Is there anything on the driveshaft that would cause this? Like a balancer or stabilizer that could go bad? Can't really see the driveshaft because of the heat shields.
lobuxracer (04-19-23)
Trans mount wasn't the fix and it is actually worse now. It is really loud at idle not even moving. In Park and N it goes away. Under a load it is very bad. I'm thinking its something with the exhaust. Taking it all off tomorrow to see it that changes anything.
minator (04-25-23)
