Brembo vs OEM pads
Brembo vs OEM pads
Has anybody used these brembo ceramic pads and if so how do they compare to the OEM pads?
https://www.brembostoreusa.com/produ...ad-set/P83146N
Tech Info Resource
I had a very bad experience with Carbotech 1521s. I won't run them again. Their track pads are great, but the 1521s wore out the root of the disc before the outer edge. That's bizarre.
After some digging I ended up going with the Textar pads since it seems like the consensus is that these are the closest to OEM pads for a much better price
https://www.brakebook.com/bb/textar/...F6854E?reset=1
So, after owning a few ISFs over the past 12 years, and going through various suggested brake pad/rotor brands, for street and beginner/intermediate track driving, the factory OEM brand performs the best. Tried textar, brembo, carbotech, none of them had the best “balance” for braking feel / performance compared to OEM. It’s as if the OEM parts are manufactured differently. Could be psychological, but there is definitely a difference as the pads wear.
RJMacReady (06-01-24)
Another option to consider is Ferodo DS2500 Front (FRP3100H) and Project Mu HC+800 Rear (PH8R106). The Ferodo's dust a bit, the HC+800 not so much. But they work well when hot and cold. I like these pads much better than EBC Yellowstuff on this car.
Discussion thread.
SpeedFreaksUSA package link.
Discussion thread.
Tech Info Resource
lobuxracer (06-03-24)
I've tried all kinds of brands too on the isf
Changed brakes maybe 8 times or more
The Textar is not identical. Even the backing plate is not identical to oem.
Used oem a few times.
Next to try ebc yellow. Might be noisy and we will find out
I found the Ferodo/PMU recipe above had better cold bite and vastly superior warm bite compared to Yellow. This recipe will dust maybe 25% more than Yellow from aggressive driving and has an occasional subdued squeal when cold, or at least it has for me.
The following 2 users liked this post by ChpEng:
RJMacReady (06-06-24),
Rossi (06-12-24)
