View Poll Results: What will be the IS-F final HP number
400-405
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
5.00%
405-410
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
4.38%
410-415
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
13
8.13%
415-420
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
25
15.63%
420-425
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
56
35.00%
Over 425, I was thinking like 600.....
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
51
31.88%
Voters: 160. You may not vote on this poll
What will be the IS-F hp?
Tech Info Resource
My best source says 432 hp. I'll stick with that...
Bear in mind C/D reported months ago that the 5L V8 had made as much as 483 bhp in an (at the time) IS 500 mule. To me, part of the answer may depend on other F-series cars. If the LF-A makes around 570 bhp as recently reported and the GS-F 500 with potentially a detuned version of the LF-A's 4.8L V10 making about 500 bhp, Lexus can afford to stretch a bit on the IS-F 500 and give it 450+ bhp without having the power and performance compression issues that afflict the supercharged AMG cars significantly and the turboed AMG cars to a lesser degree.
If Lexus gets the same 82.6 hp/liter from the 5L motor it has gotten from the LS 460's 4.6L V8, the car would produce 413 bhp. To me, that seems overly conservative since the RS4 and new V8 M3 are both producing similar power with less displacement. Lexus repeatedly says the car will have more than 350 lb-ft. Given that the 4.6L motor produces 367 lb-ft, it stands to reason an out and out performance motor could have substantially more bhp/liter than the 4.6L motor and a slightly less torque peak that a higher horsepower peak would imply. If Lexus adopts the same approach with this motor that Toyota adopted with the new Tundra 5.7L V8, that is to say more power and torque than anything in its class, I think we'll all be happy campers.
Hi All. I'm a new member here and just registered tonight. I'm stoked about the IS-F.
My estimate/quess is 437 hp, and I'll let you try to figure out how I came up with that number
My torque estimate is 376 foot-pounds.
Does the person with the closest guess win a prize? LOL
This is a tough guess. The fact that Lexus says "400+hp" makes me want to think that they will do something wimpy like 415hp.
If it indeed has the same specific output as the 4.6L, then that would be about right.
However, The optimist somewhere deep down inside of me whats to think that the F division will do for Lexus, what Lexus they did for Toyota in 1989, just this time in the performance arena.
The fact that Yamaha is tuning the engine heads, and the designation is 2UR-GSE makes me think that this engine will be more than just "400+hp".
I want to believe this motor has serious potential and might just go toe to toe with Mercedes offering around 450hp. Furthermore, the torque figure on the hybrid iteration of this motor is 389 ft/lbs. In 'F' trim, that has performance tuned heads and according to the tach, redlines at about 7000rpm (as opposed to 6500rpm).
so at worst, I say 415hp/390ft-lbs
at best (and here is hoping), at least 450hp/400ft-lbs
I voted somewhere in between, 420-425hp
You are right about my hp number being an extrapolation of the IS350 rating
I agree that engine can easily be tuned for very high power and also that they will engineer the engine for higher power, with the sacrifice of some low end torque. With the 8 speed transmission, and the right gearing, the 375+ lb-ft of torque will be plenty. I have no inside info. I'm certain the IS-F will be very impressive. I think Lexus needs to beat BMWs new M3 in the power department, but I don't think they will go as high as the power of the C63 AMG Mercedes.
That's easy, it's a simple mathematic extrapolation of the HP/liter ratio of the IS 350. Do I win a prize?
I have no idea how you arrived at the torque number, inside info?
I similar extrapolation of the IS350 torque number would put the IS-F at 395 lb.-ft. Joking aside, I like your estimates. I am no gearhead, but I suspect the G heads are high flow which would mean higher peak HP and rpms at the expense of some torque. I think Lexus could tune the engine for 450 easily, but given their emphasis on reliability, drivability, emissions and gas mileage they will probably opt for a lower number. I second your guess of 437HP and 376 lb-ft. If we are right this car is going to put up some pretty impressive performance numbers (if they can keep the weight below 3700 lbs.)
Guest
Posts: n/a
Well this is the same engine in the LS 600hl and DETUNED I believe it makes 400hp and the electric motors make up the 38hp....
So this new 5.0 could really be a beast...Lexus has always had lower displacement than the Germans with equal or better acceleration.
One final hp thought.....you can bet your bottom dollar that Lexus marketing leaned heavily on engineering to make sure they beat the 420 hp number of the M3 and RS 4 (437hp would also give the IS-F bragging rights over the new 430hp Vette
Lexus Connoisseur
Over 400 HP. Guaranteed!
