"Official?" Japanese Market IS-F specs...
Hope this is not a repost, but the details of the IS-F specs are as follows:
1 ps = 0.9863201 hp
415 PS = 409 HP
500 NM = 368 ft-lbs
1690 KG = 3720 pounds
Redline: 6800 rpm
(Note: Specs are fore the Japanese market) http://http://blog.lexustimes.jp/archives/51098904.html
code = DBA-USE20-FEZRH
exterior size:
L=4660mm
W=1815mm
H=1475mm
W/B=2730mm
FrontTrack=1560mm
RearTrack=1515mm
curb weight:
1690kg
Brakes:
Front: Brembo 360mm ventilated disks with six calipers
Rear: Brembo 340mm ventilated disks with four calipers
Suspension:
Front: Independed double wishbone and coil springs with strutbar and lower stabilisator
Rear: Independend multi-link suspension and coil springs with lower stabilisator
Tires:
Front: 225/40-19 8J
Rear: 255/35-19 9J
BBS-alloys
Engine:
Code=2UR-GSE
Size=4996cc (5.0l) (95.0mmx89.5mm)
Layout=V8 at 90degress.
Head=chain driven DOHC with Dual VVT-i, crossflow hemi head.
Injection=D-4S (port & direct sequential multipoint feul injection)
Intake=dynamic two-stage intake
Thorttle=ETCS-i (electronic throttlecontrol)
Power=305kW(415ps)/?rpm
Torque=500Nm(51.0kg)/?rpm
CR=11.8:1
Readline=6800rpm
MPG=8.2KM/L
Transmission
8 speed floormounted semi-automatic transmission with pedals on steeringwheel.
1st 4.596
2nd 2.724
3rd 1.863
4th 1.464
5th 1.231
6th 1.000
7th 0.824
8th 0.685
axle=2.176
reverse=2.937
Performance:
Electronic Limited=250km/h(180km/h for some countries). 300km/h is the highest speed on the dials.
270km/h without limiter possible (unknown if this is the max speed of the IS-F)
1 ps = 0.9863201 hp
415 PS = 409 HP
500 NM = 368 ft-lbs
Redline: 6800 rpm
exterior size:
L=4660mm
W=1815mm
H=1475mm
W/B=2730mm
FrontTrack=1560mm
RearTrack=1515mm
curb weight:
1690kg
Brakes:
Suspension:
Tires:
Front: 225/40-19 8J
Rear: 255/35-19 9J
BBS-alloys
Engine:
Code=2UR-GSE
CR=11.8:1
Readline=6800rpm
MPG=8.2KM/L
Transmission
1st 4.596
2nd 2.724
3rd 1.863
4th 1.464
5th 1.231
6th 1.000
7th 0.824
8th 0.685
axle=2.176
reverse=2.937
Performance:
Class leading with 409hps??? my ****!
Thanks for posting.
But I honestly hope that 409hps is not true. That would be a big let down from 5.0L displacement when BMW is yanking 414hps from l one liter less.
Thanks for posting.
Can anyone confirm the blog says "max power & torque is over"? I clicked on that link & it wasn't working for me.
Please believe me.
最高出力(NET) 415PS(305kW)以上
最大トルク(NET) 51.0kg・m(500N・m)以上
Last two characters (以上) mean OVER.
Yeah!, you can enter the blog by clicking following link.
Please believe me.
I highly doubt the HP/TQ figures are correct! Unless Lexus really did something stupid.
According to my detailed calculations using a program which I made with given dimensions as input, I am getting peak around 429.84HP @ ~6400-6500RPM and around 376ft-lb @ 4800-5000RPM.
I also did IS250 and IS350 HP/TQ graphs and compared it to the actual engine dyno numbers and my calculations were off by few percent (i.e. ~5%). However, the numbers above take into account this percent difference.
BUT, you can never be certain as there are many things that Lexus can do to not take full advantage of the engine. .
Those are NOT official numbers. For one thing, the HP and torque numbers are wrong. Just by that, I would question all the other specs. We already know for a fact that HP will be over 414HP and torque will be over 370 lb-ft.
And to the OP, how is this "official complete" specs? Are these specs directly from Lexus? Is this a Lexus press release? Mods please change the thread title to speculated specs.
Keep in mind the ports and valves on this one are different than anything we've seen in awhile. The heads have a G designation, so comparing this to the F heads may be off a few percentage points as well especially at peak. I'm still sticking with the 432 I heard from my reliable source.
