Second Minor Mod: Xenon Match Fog Lights
Old 03-13-08, 01:10 PM
  #31
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Originally Posted by Isfast
The bulbs in my fogs were 9006 and I replaced them with 9006 and the manual says 9006, so I am confused.
Now thats interesting...
Maybe US Spec 9006 & Hawaiian Spec H-11
Old 03-13-08, 09:14 PM
  #32
chikken
chikken's Avatar
When I bought it, its says that 100% of the manufacturing parts are from japan. Hawaii's lexus cars are shipped directly from Japan also. Not sure about the cars in the main US.
Old 03-14-08, 11:04 AM
  #33
Joe Z
Joe Z's Avatar
We get the same... However, I am sure you / we get different DOT regulations...
So i wouldn't be surprised if a Fog Bulb is changed for the US version..
Out of curiosity do your back tail lights have the 4 Leds on the side reflector??? or not..
USA gets the 4 leds, while non US spec gets no leds.
Here is a reference post showing a Japan & US Spec IS-F tail light.
https://www.clublexus.com/forums/sho...5&postcount=64
https://www.clublexus.com/forums/sho...4&postcount=95
Joe Z
Old 03-15-08, 07:54 PM
  #34
chikken
chikken's Avatar
Joe Z
yes they do have those 4 leds on the tail lights.
Old 09-04-09, 06:43 PM
  #35
caymandive
11 Second Club
caymandive's Avatar
You are correct, the IS-F uses H-11, while the reg. IS uses 9006..
Joe Z
I'm considering doing a 3000k HID setup for the IS-F fogs. Is it confirmed that the IS-F fogs are H-11's?
Old 09-04-09, 07:23 PM
  #36
Supraman16
Supraman16's Avatar
Yup, the IS-F fogs are H11's, NOT 9006 or 9005's...Darshana S...
Old 02-05-10, 09:44 PM
  #37
lx470man
lx470man's Avatar
when you guys mention time to change the parking lights do you mean the daytime running lights? if so what is the size for those lights and if i change them with the fogs with hoen will the daytime running lights also be the same color as the low beams and fogs? i want everything to match
Old 02-06-10, 04:33 AM
  #38
IS-Fly168
IS-Fly168's Avatar
Looking good... !!
What exact size are the fog light bulbs???
For the parking lights I went with the Polarg M-4's...
Glad the bulb swap is easy... on the ISx50 we have to pull the liner on the passenger side wheel-well to access the bulb.. our drivers side is super easy with a small access panel / door.
Joe Z
H11 in the Fogs Bro
Old 02-06-10, 04:35 AM
  #39
IS-Fly168
IS-Fly168's Avatar
Drl are your high beams, which is 9006 and the little bulb that sits on top is called either a 194, 168 or a t10
Old 02-06-10, 06:53 AM
  #40
VSL-F
VSL-F's Avatar
I've had the Hoen Xenon Match fog's as well, and they look good! Now I want to change my parking lights. Is that an easy install?
Old 02-09-10, 09:38 PM
  #41
Joe Z
Joe Z's Avatar
Thumbs up
Originally Posted by IS-Fly168
H11 in the Fogs Bro
My post was almost 2 years old... Bro...
Old 02-16-10, 02:14 PM
  #42
lx470man
lx470man's Avatar
i emailed hoen directly and they said the is-f fog lights are 9006. what is going on which do i buy?
Old 02-16-10, 05:41 PM
  #43
Isfast
Isfast's Avatar
I am the OP. I screwed up. Should be H11
jbone29
03-23-15 11:23 AM
melIS350
Lighting
04-13-11 08:34 AM
TAMEDV8
13
06-04-10 11:53 AM
DarKnight
Lighting
24
05-14-07 04:53 PM
Quick Reply: Second Minor Mod: Xenon Match Fog Lights
